Scratch Build – In Progress No name for the moment [The case is here ✔]
Discussion in 'Project Logs' started by leop93, 4 Nov 2013.
  1. leop93
    leop93 What's a Dremel?
    23 Oct 2013
    New Mod in preparation.
    I will add more infos step by step. Feel free to subscribe, you are welcome.
    # Partners: (??)
    # Program:
    Choice of the components
    Modelling of the whole project (final rendering)
    Modelling of the structure of the case
    Modelling of the tubing
    Fabrication of the aluminium "monobloc" structure of the case
    Modelling of the various facades of the case
    Fabrication of the various facades of the case
    # Configuration:
    ■ Hardware
    Intel i7 4770K
    Gigabyte Z87N-Wifi
    eVGA GTX 580 SC
    Corsair Dominator GT 2x4Go PC15000 C9
    Samsung 840 EVO 250Go
    LDLC QS-520 FLP (Seasonic 520 Fanless Platinum)
    Sleeves MDPC-X Black & Vivid Violet
    ■ Watercooling
    Swiftech MCP350
    EK Supreme HF Nickel-Plexi
    EK FC580 GTX Nickel-Plexi
    EK FC580 GTX Backplate Black
    EK RAD-XT 240 x2
    Corsair SP120 PWM Quiet Edition x4
    Colorant Feser View Active UV Dye Purple
    WB RAM Plexi
    Top Laing DDC Plexi
    Resevoir 150/175 x2
    # Modeling:
    ● The aluminium "monobloc" structure
    ● Facades of the case
    ● Final rendering
    # Pictures of the components:
    ■ Case
    ■ Case with components
    ■ Hardware
    ■ Watercooling
    # Progress of the project:
    [11/10/2013] Reception of the first package of Hardware
    [13/10/2013] Modelling of the complete case
    [19/10/2013] Modelling of the structure of the case
    [20/10/2013] Begining of the fabrication of the structure of the case
    [21/10/2013] Modelling of the tubing
    [next step] Begining of the fabrication of the facades of the case
    # Final pictures:
  2. leop93
    23 Oct 2013
    Hello
    I realized that by this side, the fans will take the air from outside to inside the case. And I don't want it. Then I will make a new rendering with fans in the same position from that picture:
    I will also replace the "front" reservoir by a 100mm version because in reality, the one I want is 175mm long and it's too much for the space I have.
    And for the end, I am doing some rendering for a "murderbox-style aeration" on the top of the I/O shield, like this:
    [​IMG] [​IMG]
    If you have any question or request, feel free to ask. ;)
    Good evening
    Leop93
  3. Carrie
    Carrie Multimodder
    18 Nov 2010
    Erm ... before a mod gets on your case ... I think you forgot to read the rules for scratch build logs ;) Looks like it's going to be good though :thumb:
  4. leop93
    23 Oct 2013
    Hello Carrie
    Thank you for your comment about the rules, I will edit this weekend my first message to follow them. I am sorry. :(
    And I will create a good & beautiful topic. ;)
    Thanks for the Mod. I hope it will be at least as good as the 3D rendering.
    Leop93
    EDIT: And there is a real picture of the build to don't see my topic locked. More this weekend. :geek:
  5. Carrie
    Carrie Multimodder
    18 Nov 2010
    Just post one bit of actual work on the build asap and you'll be fine ;)
  6. leop93
    23 Oct 2013
    Hello Guys & Girls ! [​IMG]
    Here is some pictures of my home-made case. :)
    Have a good end of weekend
    Leop93
  7. Marquee
    Marquee Mac Pro Modder
    22 Jul 2005
    Great start.
    I was wondering with acrylic tubing taking off now, why not just bend the tubing for all the 90 degree bends. You will save a boat load of money on fittings and save all lot of space.
  8. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    Additionally, what's with the dual reservoirs for a single loop? Aesthetic choice?
  9. leop93
    23 Oct 2013
    @Marquee, thank you. First, I thought to bend the acrylic tubes, but finally I love too much the "mechanical/industrial" style of all that metal fittings. :naughty:
    @Primum Agmen, yes it's purely esthetic. With a blank at this place, it seems very empty.
  10. leop93
    23 Oct 2013
    Hello everybody !
    Before the work of this weekend, there is a little picture of what will be fitted in my case:
    Have a nice day
    Leop93
  11. leop93
    23 Oct 2013
    Hello everybody !
    Some new today ! :D
    With the middle plate:
    And without:
    Have a good sunday
    Leop93
  12. leop93
    23 Oct 2013
    Inspired by MurderMod™.
    More in the night, stay tuned. :dremel:
  13. sebar
    sebar What's a Dremel?
    6 Jul 2013
    Wow, this is a nice build so far. Great work on the renders. I also like the grills you cut into the aluminium.
  14. leop93
    23 Oct 2013
    Thank you Sebar. :lol:
    Some other pictures for tonight:
    :dremel:
  15. leop93
    23 Oct 2013
    And the final shots before going to sleep...
  16. k.3nny
    k.3nny Minimodder
    27 Jan 2010
    looks real good! wanna see more now :D
  17. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Nice job !
