Scratch Build – In Progress Project 'Silver Ghost'
Discussion in 'Project Logs' started by montymole, 12 Sep 2014.
  1. montymole
    montymole Rigid Tubist
    24 May 2010
    Silver Ghost​
    This is the 2nd Scratch Build that I am doing this autumn and after a lot of thought and talks in the workshop with E22 over this steel frame that was from a mining rig about how it could be used as the base for a nice case so I started to get the frame stripped down and cleaned while E22 Designed the Case for me.
    My Sponsors​
    The frame​
    Here are the early renders of the case but this is subject to change over the next week or so when we make some final plans and get some brushed stainless laser cut.
    Watercooling has been sponsored by EK so big thanks to them for the help. Full hardware list is yet to be decided on may be X99 but if Asus release the Sabranco ??
    Some EK Fittings they sent me a few months ago
    The Colours to be used are next up
    That’s all for now folks hope you like it so far
  2. bulldogjeff
    2 Mar 2010
    I like the idea behind this one and the design.. I also like the look of the EK fittings, very sleek
  3. montymole
    24 May 2010
    Thank's Jeff Myself and Nate had a good think about it and he came back with the design giving me more to work with in planning the loop. The whole feel of the PC will be very Toned down Grey, silver, White and as little Black as possible but this is dependent on the mother board :D
  4. Bad Fenny
    Bad Fenny What's a Dremel?
    20 Aug 2014
    Looks like it is going to be a sweet design. I love the openness of the front plexi. Looking forward to seeing it unfold.
    Cheers
    Fen
  5. Nexxo
    23 Oct 2001
    That is such an obviously elegant layout (How come I didn't think of that when I was trying to design a wooden steampunk case?!? :duh: ).
  6. Darkwisdom
    Darkwisdom Level 99 Retro Nerd
    27 Aug 2011
    I love the design, minimalist and sleek. Will be watching. Also, there aren't enough 'silver' projects.
  7. montymole
    24 May 2010
    Hey thanks guys this week there will be a big update on hardware and some progress om the final design so I can get to work once the panels are cut
  8. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    A nice start,look forward to the rest.
  9. Ianovski
    Ianovski Rawr!
    10 Mar 2011
    Another build by you? You're going HAM! Great design, will follow :D
  10. montymole
    24 May 2010
    Thanks BNeg rather liking this a lot and really cannot wait to get the panels cut and see how it looks in the flesh we have stuff to tweak before then but me is excited
    Ian yes I know I am crazy but I love this so much it would be a shame not to use all the space in the workshop so I expect to have a few done before the year is out I have so much time on my hand as I am at home looking after my mum so I find it easy to do them both as there is no travelling All my work is at home.
    So thank you for looking at this little build log and I hope to have something juicy to show very soon :)
  11. aggression
    aggression What's a Dremel?
    3 Feb 2013
    Subbed.
  12. MarkyG
    MarkyG What's a Dremel?
    31 Jul 2014
    Dammmnn those EK fittings look lovely!
    Love the cable sleeving too!
    Makes me want to do another build!!
  13. montymole
    24 May 2010
    This is my problem I see things then want to do another project I have made space in my room for a few on going builds once the messy bits are done in the workshop and I have time on my hands so all I can do is keep modding :)
  14. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    looking forward to this ;)
  15. montymole
    24 May 2010
    Thank you have to say I am very much excited to have a real one of a kind PC :thumb:
  16. MarkyG
    31 Jul 2014
    It certainly will be unique, can't wait for more unfolding of this build. Love the design
  17. montymole
    24 May 2010
    The Specs
    Hello again Folks back with a very small update and a Spec list. I have known for some time now the Asus will be doing a limited run of the White Sabertooth Called the Sabranco I have spoken to a friend in Asia and they are very close so this will be the board for this project.
    The Specs:
    Intel 4690K
    Asus Sabertooth Mk S
    HOF 780 GTX x2 SLI
    Corsair 16Gb Dominator Platinum 2133
    Corsair HX850i
    Corsair Force LS 240GB x2 Raid 0
    EK 540mm WE Rad
    EK EVO White CPU Block
    EK D5 and Top
    EK 250mm X3 Res (White)
    EK 780 HOF Blocks
    EK HDC 12mm OD Nickel Fittings
    E22 Ultra Clear
    Aquero 6 XT
    Still not got the Final Design down yet really want it to be perfect and need to incorporate a transition plate and maybe a waterfall Res into the mix so one more week of planning before the action starts.
    Thanks again for looking at my work logs see you very soon :thumb:
  18. DBRichard
    DBRichard What's a Dremel?
    6 Apr 2014
    I've never seen this project :/ but now I want to see more. :)
  19. colinmcr
    colinmcr What's a Dremel?
    1 Jul 2014
    Sabranco....begins to drool
  20. montymole
    24 May 2010
    Thank you guys here is a small update with some Hardware from Corsair that arrived this week.
    Massive Thanks to Corsair for this Fantastic bundle :)
