Modding Plastic painting?
Discussion in 'Modding' started by Bboy_Jon, 13 Mar 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    can plastic bezels be painted to have a mirror finish? cuz this guy did
    how? should i do that with my case?
  2. Zephyr
    Zephyr Go V-Boy, Go!
    1 Oct 2004
    How? By doing a lot of painting and sanding. Probably somewhere around 15 coats of an ultra-gloss black, with high-grit sanding between each coat. Then a good few coats of clearcoat, again with sanding in between.
    Should you do that with your case? Completely up to you brotha.
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok so its the same as getting a mirror finish on the side panels (which is metal) right?
  4. crimandevil
    crimandevil What's a Dremel?
    30 Jun 2004
    How about reading the guide you took those pics from and quit stealing bandwidth. Host the images yourself. :rolleyes:
  5. offroadracer789
    offroadracer789 What's a Dremel?
    9 Dec 2004
    He tells you how to do it in his guide. Wow, you went to the guide on his site, copied the picture urls, then made a thread with the pictures asking us how he did it. :eyebrow:
