Build Advice Corsair 450D building space
Discussion in 'Hardware' started by hirezo, 27 Nov 2015.
  1. hirezo
    hirezo Minimodder
    27 Jul 2009
    Just a quick question guys.
    Does anyone know if I will be able to fit a Corsair Hydro Series H110i GTX High Performance 280mm inside of a Corsair 450D and also a Nvidia gtx 980ti ?
    Thanks in advance guys.
    :D
  2. hirezo
    hirezo Minimodder
    27 Jul 2009
    Anyone?
  3. Parge
    16 Jul 2010
    Not *that* hard to find this out......
    Seven fan mounting points for high-airflow and watercooling applications
    If your high-performance system build requires high-performance cooling, the 450D is an ideal platform. The mounts support front, bottom and rear radiators for flexible watercooling installation options, or fans for superior ventilation.
  4. hirezo
    hirezo Minimodder
    27 Jul 2009
    Thanks Parge.
    I did see that picture when having a search around before posting the question, but I was a bit worried as I read the H110i was quite thick.
    I guess I will see how well it fits when the parts arrive tomorrow lol.
