Case Mod - In Progress [COMPLETED] Project p5yche: TT caseMOD 2016 - twin core p5, 5820K, SLI 980, full H2O
Discussion in 'Project Logs' started by DarwinPC, 5 Apr 2016.
  1. DarwinPC
    DarwinPC What's a Dremel?
    3 Sep 2015
    Hello and welcome to Project p5yche by Darwin PC!
    Project p5yche
    I'm very excited to take part in this competition, thanks to Thermaltake and all the sponsors for making this possible. :)
    Project p5yche is named, like my other projects, after mythical gods and goddesses. Psyche was the Greek goddess of the soul.
    I have some very special things planned for this mod. The most obvious first of all, is that I'll be using TWO Thermaltake Core P5 cases. These will be joined together, and will allow for some serious hardware to be built into the mod.
    The plans, mods and build updates will be posted here, so check for updates!
    Components:
    CPU: Intel Core i7-5820K 3.3GHz 6-Core
    Motherboard: Asus SABERTOOTH X99 ATX LGA2011-3
    Memory: Avexir Blitz 1.1 - 32GB (8x 4GB) DDR4-2400Mhz
    Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive
    Video Card: Asus GeForce GTX 980 4GB STRIX
    Case: Thermaltake Core P5 (2x)
    PSU: Thermaltake Toughpower DPS G RGB 1250W Titanium
    Radiator: Thermaltake Pacific RL480 (3x)
    Reservoir: Thermaltake Pacific T33 (2x)
    Pump: Thermaltake Pacific P1 Black D5 Pump w/ Silent Kit (2x)
    Fittings: Thermaltake Pacific Chrome
    Custom gaming computers and mods by Darwin PC
    Update: Build complete
    Hi guys, I would like to thank Thermaltake and all the sponsors for inviting me to this competition and making this project possible. It's been challenging at times, I was hit with many delays, but got there in the end!
    The finished build photos are below. I'll also post a loop fill video as soon as I finish editing it!
    I hope you like what I created - Project p5yche, a twin Core P5 mod.
  2. DarwinPC
    3 Sep 2015
    The Thermaltake Core P5 is an awesome case. What could possibly be better? How about... two of them!
    The two cases will be joined together to form a monster double Core P5. First of all I took the cases out and stripped one of them down, since it won't need any power switches etc. It also allowed me to get a good look at the structure of the frame.
    Here are all the parts removed:
    And here is the stripped down Core P5. It's a simple but elegant and functional design. It should be quite straightforward to work with.
  3. DarwinPC
    3 Sep 2015
    A little ;) package arrived from Thermaltake... most of the watercooling kit, and the PSU. This thing is going to be a beast!
  4. DarwinPC
    3 Sep 2015
    The hardware for Project p5yche arrived! Thanks to the sponsors - Thermaltake, Newegg, ASUS, Intel, Samsung and AVEXIR.
    ASUS X99 Sabertooth motherboard - great looking motherboard, I look forward to playing with this.
    ASUS GeForce GTX 980 STRIX - really nice coolers, it will be a shame to remove them, but this beast must be watercooled!
    Intel Core i7-5820K
    SAMSUNG 850 PRO 2.5" 512GB - this is a really gorgeous SSD, with a solid finish.
    AVEXIR Blitz 1.1 Series Original (White LED) - heaps of RAM, the heatsinks look awesome, can't wait to see the LEDs.
  5. DarwinPC
    3 Sep 2015
    Here are the templates for the radiators all in place and ready for drilling. The circled holes will be drilled, and crossed holes will not (due to obstructions or gaps). There are still plenty of attachment points for each radiator to give a solid mount.
    I finished drilling the mounting holes for the radiators. Then moved on to the points where the two Core P5s would attach to each other.
    Here are the pieces marked up:
    The holes on the edge will be fixed with rivets. The little screws attach the edge of the case to a corner bracket inside. Since the screw heads would prevent the cases sitting flush together, they will be removed. I originally planned to bolt through the holes on both cases to maintain the strength in the corner, but the holes don't actually line up. So four new holes within the corner bracket area will be drilled and tapped.
    Here are the finished case edges:
  6. DarwinPC
    3 Sep 2015
    Marking up the mounts for the 2x D5 pumps and 2x T33 reservoirs. The pumps are slightly to the right from the reservoirs, as the pump inlet is in the centre, but the ports on the bottom of the reservoir are either side of the centre.
    Finished drilling and ready for painting after a cleanup!
  7. DarwinPC
    3 Sep 2015
    Time to work on the hardware for the project. First up, fitting the i7-5820K and full cover block for the ASUS X99 Sabertooth.
    I had to remove the thermal armour from the motherboard to fit the full cover block. Here you can see the exposed southbridge and VRMs:
    Installing the CPU:
    Here is the full cover waterblock installed:
    It would be a shame to waste the thermal armour, so let's have a look at making it fit with the water block. Here you can see the parts that overlap:
    Nothing a little Dremeling can't fix...
    Here is the rough cut - fits nicely. Now just needs cleaning up and then time for paint:
  8. DarwinPC
    3 Sep 2015
    Painting the thermal armour for the ASUS X99 Sabertooth motherboard.
    First coat of primer:
    After sanding, more primer and more sanding:
    Final coat of paint:
    Now ready for clear coat and fitting back to the motherboard...
  9. DarwinPC
    3 Sep 2015
    Fitting the water blocks for the 2x ASUS GTX 980 STRIX graphics cards.
    With stock air coolers:
    Coolers removed - nice looking PCBs!
    With the water blocks fitted. I like the black/white combo.
  10. DarwinPC
    3 Sep 2015
    Cutting the backplate for the ASUS X99 Sabertooth thermal armour so it fits with the full cover water block.
    Here is the part that overlaps:
    Cutting the backplate to fit:
    And the finished motherboard (minus some detailing work that will be added):
  11. bundymania
    bundymania Bastelorakel Industries Worldwide
    4 Jun 2009
    The board looks nice !
  12. DarwinPC
    3 Sep 2015
    Thanks! Spent a whole weekend cutting, priming, sanding and painting it. I've added some details in green, will show them soon.
  13. DarwinPC
    3 Sep 2015
    Got the case powder coated white, riveted / bolted the two parts together, and started fitting the hardware to make the loop.
    Here you can see some of the green detailing I've done on the motherboard and will do elsewhere, using vinyl.
    Starting to come together...
  14. DarwinPC
    3 Sep 2015
    With the case assembled and hardware installed, it's time to construct the watercooling loop.
    I'm using the cutting tool provided in the kit from Thermaltake. This works really well, very quick and only gives a slight burr on the inner edge of the tube, that is easy to remove.
    Started off cutting the straight runs to connect the radiators to each other.
    First bend in place - connecting the left radiator to the reservoir. The bending insert and mandrel from Thermaltake made this a breeze.
    All the tubing in place, apart from the top run from the motherboard block to the radiator. This run is actually longer than 1m (the length of the tubing pieces), so I will be using the flow indicators from Thermaltake to break up the length.
  15. DarwinPC
    3 Sep 2015
    24 Thermaltake Riing 120 mm RGB fans fitted!
    Also got the top tubing runs sorted now I have the flow meters.
    Looking good in green...
  16. DarwinPC
    3 Sep 2015
    I spent a long time sleeving this week! Really happy with the neon green colour sleeving from E22, it's a nice vivid colour and will match the coolant very well.
  17. DarwinPC
    3 Sep 2015
    To fit better with the theme, I made some green and white vinyl stickers for the Riing fans.
    Leak testing!
  18. Praelia7or
    Praelia7or What's a Dremel?
    16 Apr 2016
    Seriously impressive bit of kit! reminds me of a lot of wall PC builds but more compact and better laid out, cooling must be immense with about 1.5m of radiators!
  19. DarwinPC
    3 Sep 2015
    |Thanks - it's a nice case to build with, lots of scope for customisation too.
  20. DarwinPC
    3 Sep 2015
    I made some detailing for the window using vinyl. To fit with the Greek theme ('Psyche' was the Greek goddess of the soul), I chose a Greek pattern.
    Here's a sneak peak...
