"MAMBA 540" is the name I have given to this new project is not so random. MAMBA why I chose the color green acid MB reminded me of the mamba snake for coloring. While 540 is easy to understand because it is derived from the model of the houses of the Corsair. SPONSORED by HARDWARE CPU: i5 4670k MB: Gigabyte G1.Sniper Z87 RAM: Corsair vengeance pro 8Gb 2133MHz VGA: Zotac GTX780 PSU: Corsair AX760 SSD: ??? I'm going to create a system of liquid cooling for the CPU and VGA. LIQUID COOLING Radiator: 2x Alphacool 240 UT60 CPU: Bitspower Summit EF * VGA: Bitspower NGTX780 * Reservoir: Bitspower Z-Multi 100 V2 * Pump: Alphacool D5 + Top Bitspower S Model * + Cover Pump Bitspower Silver V2 * Fittings: Bitspower * *: sponsorship Note: The rendering does not reflect the chosen hardware but it's just a visual of how it will be 90% of the final result.
Case dismantled everything I tried to install the front fans externally to gain more space for the zone pipes ...... IT WORKS! I will have to give up the dust filter but in return I gained 25mm step right to the dremel to prepare the lower zone to host the second 240
