Hi guys/gals, Does anyone know of any high cfm 40x40x10mm 5v Fans? Would be needed for a project i am currently working on? Any help would be greatly appreciated with rep
I think Noctua 40x40 x10 but its @ 12v ,there is a Evercool 40mm 4cm 40 x 40 x 10mm 3 Pin 5 Volt but you are getting towards delta fans l
The only fan I have seen with a high cfm is a 40x40x28 Sunon which does 31.5cfm and that's coming from the U.S.A . Can you use a fan converter 40/60
This is all I could find http://www.sunon.com/pro.php hope this helps you on your way with you project
You will need to make sure whatever you are connecting the fan to can output enough watts, most fan controllers max out at like 10watts I know the deltas 120mm are 31watts Sent from my SM-G900F using Tapatalk
