Windows Looking for HTML editor
Discussion in 'Software' started by javaman, 27 Mar 2015.
  1. javaman
    javaman May irritate Eyes
    10 May 2009
    Hey everyone,
    I'm doing a course at college through work and one of the modules is web design. Due to the quality of teaching (or lack thereof) the class has been left to themselves and sipmly given a task of design a website.
    Having no experience in wed design or development I started working through w3schools and codeacademy resources and playing with code in notepad++. However I am now looking for a proper IDE to do development in.
    My background is in .net development and part of the course is using ASP.net using Microsoft web matrix so instinctively I checked Microsoft's product and came across Expression Web 4. It seems to be ok but support looks to end for it in the near future. Due to being new to this and wanting to keep on working with what I've learnt.
    So can anyone recommend a decent IDE that
    • supports HTML, CSS and Javascript
      Has decent set of features that will make development easier (being new I still don't know what tools will be useful or even exist).
    A few web results that I came across recommend Quanta Plus, Drupal and Aptana but don't seem to really lay out a decent reason to choose one over the other. Any advice and recommendations very welcome.
  2. saspro
    saspro IT monkey
    23 Apr 2009
    Visual Studio? There's an express version designed for web etc
  3. rici1241
    rici1241 Minimodder
    4 Jan 2011
    Visual studio community. Its free, and supports nearly all languages through plugins, so if you want to try a new language, you won't require a different IDE.
  4. javaman
    10 May 2009
    Thanks guys ill check that out. Visual studio would be the best since I'm fairly familiar already with it. VSCommunity looks perfect for everything so ill play around with it this weekend
  5. GoodBytes
    20 Jan 2007
  6. javaman
    10 May 2009
    Looking deeper at web matrix support it seems to have confused me further. Who is it aimed at? It seems a really specific product and Visual Studio Community seems to make it redundant. MS products are a bit over the place.
  7. RedFlames
    23 Apr 2009
  8. faugusztin
    11 Aug 2008
  9. sparkyboy22
    sparkyboy22 Web Tinkerer
    3 May 2010
    +1 for sublime text. Couldnt live without it now!
  10. law99
    law99 Custom User Title
    24 Sep 2009
    Freaking awesome. I use it for networking also... good packages available syntax highlighting, & so on.
    Loved the ability to run snippets of PHP also with, what I think, is called anypreter. Helps with little modular snippets.
  11. deathtaker27
    deathtaker27 Modder
    17 Apr 2010
    You can use visual studio with a oh plugin
  12. HeaverNothing
    HeaverNothing Professional Idiot
    7 Aug 2013
    +1 for Brackets! I found it very easy to use and looks sleek
  13. Hanshin
    Hanshin What's a Dremel?
    28 Mar 2015
    +1 for Sublime Text. Really easy to handle!
  14. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
    I use Microsoft expression web4, which I believe is now free, but no longer supported by Microsoft
    edit: ignore me speed reading I always miss things til I go back again
  15. scimmy
    scimmy Minimodder
    17 May 2005
  16. hughwi
    hughwi Minimodder
    23 Dec 2003
    I use Sublime and Brackets - when you get further in, you might want something like Webstorm (so you can use Grunt, etc).
  17. roundyz
    roundyz What's a Dremel?
    16 Jan 2002
    An answer to a problem that does not exist. src = professional web dev 5 yrs. just use a text editor.
  18. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    This x30000
