Hi to all!! My names is warboy the name of the mod is CERBERO the idea is to create a rugged chassis for gaming pc. easy to carry and unique design. the structure will be made of square profiles of dimensions 4x4 cm for 2mm thick, the all welded and assembled with the aid of a Mastro Smith. will then be prepared and painted with anticorrosive epoxy primer, custom airbrushed and finished in body shop.. Thanks to Bitfenix and AVEXIR For the support!! the componets are: Motherboard: MSI Z97A GAMING 6 Graphics Card:MSI GTX 980 GAMING 4G Chassis: CERBERO --> https://www.facebook.com/cerberowarboy Ram: 16 Gg AVEXIR Blitz1.1 Series - DDR3 (4x4Gb) Power supply: Bitfenix Fury 650G Fans: 6 x Bitfenix Spectre Pro LED white LED: Alchemy 2.0 Magnetics Led Strips CPU: Intel i7 4790k Fan Controller: LAMPTRON CW611 xtremehardware.com edition SSD: Samsung PRO 128 GB HDD: 4 TB WD Green (2 x 2Tb) Liquid cooling: EK XRES 100 D5 vario Alphacool NexXxoS XP³ Light - Acetal Edition Alphacool NexXxoS ST30 Full Copper 360mm Start by cutting the iron... We check that it is all right we weld...
nice! i just thought that im kinda fed up with the giant square cubes with 15 radiators and 200 fans..... and the next one i open up is this one! thank you for the refreshing build
Thanks Guys the chassis is almost finished, then it will be finished with epoxy paint and airbrushing
