Hi Guys I am planning on watercooling my PC. At the moment, I have a i7 920 which is at 1.325 v and I will be adding a GTX 480. I currently have a 320 black ice stealth and an old 120 radiator which is only slightly thicker. Now will this cool the CPU and graphics card? I am not looking to overclock the graphics card rather I would like to keep it quiet! Thanks
Yes should do. I have a Q6850extreme, a fully water blocked 790i Ultra and 2 x 295's in one loop through 2 x 360 GT Stealth Rads I presumed you meant 360 not 320? Anyhow Temps are fine
Haha, yes i mean 360. its all go on this thread this morning! and thanks. i guess that 1 360 rad should be ok then
Hi Just another quick question. Do you know if the GT stealth uses m3 or m4 screws? and what length shoudl i get? thanks once again
Don't know about the thread size but they should be just long enough to go through the metal it's screwed into but no more! So I couldn't be more help but just measure how thick the fan is and then how thick the metal is and add them together! that should give you a good idea.
M3 I think however I have buggered about with mine in several cases I have had to re thread them in m5 now. I think I might have a pristine rad in the garage still .. I'll check the thread tonight if I get time
IDK about that -- originally I was running my CPU and NB on a 360 stealth and was getting results comparable to a good HSF (Wasn't happy with temps over 4Ghz with no HT.) Obviously YMMV as you may get further on lower voltage than me (This chip isn't a fantastic clocker), but you're throwing a 480 into the mix as well. Depends on the clocks you want to hit. Did I mention YMMV?
