Can anyone suggest some remote support software, ideally self hosted not cloud based, doesn't cost a fortune, and works with Mac and windows? Looked at isl, team viewer, log me in etc but not really right for the situation.
We are looking to have something that we can host ourselves, not cloud based Sent from my Nexus 6 using Tapatalk
Thanks pookie, I tried ammyy but a lot of av picks it up as a threat, Sent from my Nexus 6 using Tapatalk
I use netsupport manager its a per machine license but you buy as many as you need with a minimum of 2 licenses, cost me about £52 inc vat it has a server for secure connection part to it as well(its fairly straight forward to setup) I should point out this is not a subscription based service either, so no yearly renewals, once you buy them they are yours forever
I have no idea on the pricing, it's probably something absured though, but BOMGAR has been the best remote support application I've used, we had it deployed on ~1000 client sites which made life so much easier than those we didn't have it on.
Thanks guys. I had a look at screen connect it looks pretty good, I'll take a look at netsupport manager too. I'll take a look at bomgar but if it is a 4 figure cost I'll be out Sent from my Nexus 6 using Tapatalk
