Scratch Build – In Progress Epic's Thermal Tower - Need suggestions for the loop route, help me! 20.05.2012
Discussion in 'Project Logs' started by Djayness, 30 Jan 2012.
  1. Djayness
    Djayness phwupupupup
    7 May 2008
    Oh...that thing.
    For the longest time after we sold the Carbide Series design to Lamptron I kind of twiddled my thumbs a bit. I used the design knowledge to create a mini case that LAN gamers could enjoy and all was well and good till the hordes of emails showed up demanding that we do a full sized build.
    Pictured, a full size build.
    So I did some designing, wow I did some designing. I'm the kind of unfortunate soul that gets in a "zone". Some days I spent almost 10 hours straight going through Autocad, making sure every little detail was correct. Like all good designers, I thought about the features I wanted in the case and a unique way to apply those features to the design in a way that made sense.
    Flat packed, skinny, tall, enough room for 360mm radiators top and bottom. Inverted motherboard tray, push and pull configurations, case filters etc etc. All of these features were those of which had been fed back to us over the course of the past two years and the set of features above could be found in very few, if any, cases already on the market.
    The biggest design challenge though was to create a case that could be flat packed and assembled, a whole new ball game for someone who has spent the past two years using weldon to bond cases together with the assistance of clamps. So without much further ado, welcome to my build log of a true prototype, one that you will actually be able to get your hands on in the very near future!
    Thanks to:
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
  2. motorsportcfd
    motorsportcfd What's a Dremel?
    25 Jan 2012
    Looks like this will be a cool build! Excited to see more!
  3. KidMod-Southpaw
    28 Sep 2010
  4. cerbrus2
    cerbrus2 What's a Dremel?
    24 Sep 2011
    And my new case is..........................................
  5. jamsand
    jamsand Minimodder
    21 May 2011
    ^ Really freaking expensive :p, Looks epic as always though. Get what you pay for.
  6. Djayness
    7 May 2008
    Actually since it's flat packed and assembled by the end user, not so exxy :)
    Check it out, more soon!
  7. cerbrus2
    24 Sep 2011
    Rough estimate of the price. If thats possible.
  8. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Including shipping to the UK from Aussieland? A buttload of money.
    I still want one. Heck. I want most of what Epic churns out. It's all pretty damn amazing.
  9. peteski
    peteski long live the pc
    8 Jun 2011
    :jawdrop: cant wait to see more :rock: :rock: :rock:
  10. Djayness
    7 May 2008
    I'm trying to keep it around the 600AUD to 800AUD mark and that all depends on the hours logged or required by the CNC to cut the entire case. Some things still need to be hand assembled such as the motherboard IO and all the joining pieces and until I finish this case, I just won't know.
    Thanks Tundra :) Shipping to the UK for full size cases that I had was around 200AUD + but since we are now flat packing, it should be much cheaper.
    In around 10 hours I will have an update, I've actually run out of acrylic but can assemble the case quite a bit with what I have cut.
  11. Djayness
    7 May 2008
    Well hey, I'm back.
    I ran out of acrylic but that hasn't stopped me from screwing together the pieces I did cut just so I could get a better idea of what the case looks like.
    It's tall...
    I haven't fully polished the pieces either and the great thing about the case is that I can do that without too much hassle. Just put the allen key into the holes the panels will come off quite nicely.
    I did, admittedly spend around an hour polishing the bottom of the case for whatever reason (you'll never see the bottom anyhow -_-) and now I have decided that I would rather the bottom to be clear so that light can shine through it.
    I was actually so caught up with this particular idea that I'm willing to cut another sheet of acrylic just to make it happen :D , this is my personal case so I wanted it to be perfect.
    I got the weekend off work so you'll see more progress then and our good friends at Razer have prepped a surprise delivery for me :)
    Thanks to:
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
    GaryP likes this.
  12. peteski
    8 Jun 2011
    man that is tall i like it :rock: :rock: :rock:
  13. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    800mm tall hmmm need 2 can use as new desk pillars :p :D
  14. Unicorn
    25 Jul 2006
    Wait, what's this now? Did I miss something?
  15. Djayness
    7 May 2008
  16. Asouter
    Asouter --------
    18 Jan 2012
    Glad I didn't see this before I'd started my build.....Like it lots
  17. debs3759
    debs3759 Was that a warranty I just broke?
    10 Oct 2011
    Very nice! That would swamp even my LD case - I have to remove a drawer from one of my desks to get that under, I would have to remove the whole desk to fit one of these in!
    While so many people are looking for smaller and smaller computing options, so many modders are going big these days :)
  18. Djayness
    7 May 2008
    The feedback we got initially was that for watercooling, fitting at least a 360 and a 240 was considered a bare minimum these days.
    Luckily we've gone for a pull push 360mm radiator down bottom and a single 360mm radiator up top, plenty of airflow.
  19. Unicorn
    25 Jul 2006
  20. Djayness
    7 May 2008
    Thanks for the sub :D
    Time for an update?
    Completed the side panel and was one of the few times I did the engrave on the outside instead of the inside of the panel. I really like how it turned out.
    Side panel on and I didn't quite like the legs I put on so I've decided to make that entire bottom area another layer of clear acrylic like a rim. This hopefully will light up, in theory...
    Lets hope I'm right!
    In the meantime I also dived into another sheet of clear acrylic for the bottom. Going for an awesome amount of blue light!
    You can see how the bottom attaches with m4 screws. I can easily swap the bottom out later for another config, for example sake I could put a 280mm radiator and some pump mounting holes on there instead. It's a modular case!
    I'm sure that was a painful tease but I'm working on designing that bottom bit and hopefully I'll come back with some progress on that tomorrow.
    Until then!
    Thanks to:
    Razer
    EKWB
    Fraglabs
    Asus
    Republic of Gamers
