Overclocking HOWTO: Overclock C2Q (Quads) and C2D (Duals) - A Guide v1.6.1
Discussion in 'Hardware' started by graysky, 25 Mar 2008.
  1. graysky
    graysky What's a Dremel?
    25 Mar 2008
    Edited on 09-May-2008: Guide is now version 1.6.1 – minor corrects made and slight re-ordering of sections.
    Before you continue, I wrote this guide with the newbie in mind, so please don't reply criticizing it for being too simplistic -- it's this way by design. Also know that the steps for overclocking apply to all chips: quads, duals, single-cores, or triple-core processors. You can use the basics taught in this guide with any modern machine.
    I wrote the guide originally using a Q6600/Asus P5B-Deluxe, but recently sold that machine and upgraded to an X3360/DFI LT P35-T2R. I didn’t want to change the first half of the guide, so it’s still based on the Q6600/Asus board. The newly written section about finding a minimum stable CPU and MB vcore section is written based on my actual experience finding stable settings for this newer machine. Again, the steps for overclocking are pretty independent of this subtle change. Finally, I take no responsibility for what you do with the information in this guide. Overclock your hardware at your own risk.
    Overlocking Basics
    Before you start, read your motherboard manual. Know how to reset your BIOS in the event that you are too aggressive in your CPU settings and it doesn't complete a POST (Power On Self Test, that beep when you first turn the machine on and it starts up means you passed the POST). Some motherboards reset automatically if you switch off the power supply for 30 seconds or so. Others require you to move a jumper to reset them.
    The basic formula you need to know for CPU speed is:
    Code:
    CPU Speed = CPUM x FSB
    where CPUM is the CPU Multiplier, and FSB is the front side bus.
    Example: The Q6600 runs at a factory setting of 2.40 GHz. That's the product of a 9x multiplier and a 266 MHz FSB (quad pumped it's 1066 MHz but we're not quad pumping these numbers). So CPU Speed = 9 x 266 which is 2,394 MHz or 2.40 GHz.
    Below is a list of Intel chips. Most of them, including the Q6600, have a "locked" multiplier – meaning it can't go above a certain value (9x in this case). The only way to increase the CPU speed beyond the stock value is by raising the FSB. Other "Extreme" chips like the QX9650 or X6850 have “unlocked" multipliers; you can raise their multipliers above the stock value. These chips are denoted from the standard stock by the letter “X” in their model number.
    For reference, here are all Intel offerings as of May/’08:
    My first quad system was based on a Q6600 at 9x333=3.00 GHz (25 % over factory). I found the max it can go when cooled with air is 9x370=3.33 GHz (39 % over factory), but it just ran too hot for me. Every chip is different... you might be an unlucky owner of a chip that just doesn’t overclock very high at all.
    Overclocking is more complicated than just adjusting two settings in the BIOS, because as you increase the FSB, you'll also need to increase the core voltage (vcore) which is the actual juice going to the processor. As well, you may have to increase the other voltages on the board like: memory, FSB, NB, SB, ICH chipset. There are also parameters controlling your memory that may need tweaking as well. Don't worry about them for now. The board can manage these automatically which is what you should do initially. When you finally decide on an overclock number, you'll want to go back and minimize your voltages to minimize your heat production. We'll get into this later. For now, you want to verify you can successfully POST, and verify that your system can run stable at the settings you've selected.
    Pre-Overclocking Checklist
    Before you think about overclocking your system, you'll need to be sure you're using quality parts that can handle the increased stresses.
    1. Motherboard
    I decided not to maintain a list of motherboards that are known to be good overclockers; keeping the list updated would be too time consuming. I only mention this because if you’re using some generic MB you got free with the purchase of your CPU, you’re probably not going to be able to overclock it.
    2. Cooling
    Cooling is very important since you're asking the system to produce more heat than it's designed to produce. A quad core chip will produce twice the heat of a dual core chip, so if you're using the Intel Stock HSF, you'll probably want to upgrade to something better. Again, I don’t wanna maintain a list. I can tell you that I am using a Thermalright Ultra-120 Extreme and am very happy with it.
    Here is a more recent list of HS’s that have actually been reviewed and ranked based on performance.
    Finally, there is a section at the end of the guide entitled, “Temperature Management” which I would strongly suggest you at least have a look at since it contains some good info. For example, for under $5 you can probably shave off ~10-15 % of your NB (North Bridge) load temps simply by adding a small fan to the heatsink even if it was never designed to have one (attach it with a zip tie):
    3. Memory
    You will need memory that can keep up with your overclocked system. Again, I’m not going to keep a list. You’ll see RAM listed with timings and speeds that I’ll decode for you using the following examples:
    • The first part is self-explanatory (DDR2 memory).
    • The number after it is the data transfer rate. Simply divide it by 2 to get the maximum FSB speed for which the module is rated. Example: 800/2 = 400 MHz. Therefore, DDR2-800 can work on systems with a FSB of up to 400 MHz (anything more and you’re lucky).
    • The PC2-XXXX is designation denoting theoretical bandwidth in MB/s. Some memory manufactures use this instead of the DDR2-xxx designation. You can calculate it for any FSB you want by simply taking the FSB and multiplying by 16 (rounded in some cases). Example using a 400 MHz FSB: 400x16=6400. So you’d need at least PC2-6400 to run on a FSB of 400 MHz.
    The numbers after that are the main timings (clock cycles). In general, the lower these numbers are, the faster the memory. For more on memory timings, see this page.
    • The first part is self-explanatory (DDR3 memory).
    • The number after it is the data transfer rate. Simply divide it by 4 to get the maximum FSB speed for which the module is rated. Example: 1600/4 = 400 MHz. Therefore, DDR3-1600 can work on systems with a FSB of up to 400 MHz (anything more and you’re lucky).
    • The PC3-XXXXX is designation denoting theoretical bandwidth in MB/s. Some memory manufactures use this instead of the DDR3-xxxx designation. You can calculate it for any FSB you want by simply taking the FSB and multiplying by 32 (rounded in some cases). Example using a 400 MHz FSB: 400x32=12800. So you’d need at least PC3-12800 to run on FSB of 400 MHz.
    4. Power Supply
    There are really two major factors to consider when selecting a power supply:
    1) Quality of the PSU
    2) Power output
    I don’t have the expertise to write up this selection of the guide, so I’ll point you to this nice list written by perkam to use as a guide. More recently, TH.com wrote another article you can check out on the topic.
    There is a great article on power consumption over at TH.com that I suggest you read at your leisure. I distilled out some highlights to underscore how much power systems really use:
    Code:
    Component	Best Case	Worst Case
    Power Supply	5-15 W		40-60 W
    Motherboard	10-15 W		30-50 W
    Processor	12-30 W		60-120 W
    RAM		5-15 W		30-50 W
    HDD		3-5 W (2.5")	10-15 W (3.5")
    GFX Card	3-10 W (on MB)	25-180 W (PCI Express)
    Total		38-90 W		195-475 W
    So you can see that depending on the hardware specs, your system power requirements can approach 500 W.
    There are also a number of good online power supply calculators you can use. Find them with google as always. Here is one such example.
    5. Required Software
    Here are few utilities you'll need to continue, all are freeware.
    General System Info
    CPU-Z is a great app to display your current settings including vcore, FSB, multiplier, RAM settings, etc. This one is a must-have!
    CPU Stress Testing
    Prime 95 v25.6 is a great app for stress testing. It is very efficient at generating CPU loads equally across all your cores. There are few other apps that will stress a system as a hard as p95. Alternatively, if you’re using a 64-bit o/s you can download the 64-bit version of prime95 v25.6.
    I like to use version 25.x over the current “production” version 24.x because it [version 25.x] automatically stresses all your cores without having to load up two different instances of the app like you had to do with orthos.
    System Monitoring
    There are several options for processor core temp and system temp monitoring. For a discussion of what is different between the apps I am about to list, see this thread. PLEASE READ THAT THREAD BEFORE ASKING QUESTIONS ABOUT WHY SOME OF THESE READ DIFFERENT TEMPS!
    These first two will give you just the core temperatures (not system temps, voltages, etc.):
    Core Temp (freeware)
    Real Temp (freeware)
    The next three will give you core temps plus many other temps, voltages, fan RPMs, etc.:
    HWMonitor (freeware)
    Speedfan (freeware)
    Everest Ultimate (shareware $$$)
    Memory Testing (optional but can help rule-out bad memory)
    Memtest86+ is a great piece of software that will test your memory. Download the bootable ISO and allow it to test your system for 6-24 h. I ran it on my machine for a little over 6h 17m with no errors:
    Note that you can’t just run the memory tests without first setting up your memory in your BIOS even though they might be auto configured. This usually entails the user to specify the timings, voltage, and fsb:dram divider prior to running the tests since the memory might be stable at one given set of conditions (maybe 5-5-5-15 @ 667 MHz is stable), not unstable under another (maybe 5-5-5-15 @ 1066 MHz gives errors, but you only tested the 667 MHz level)!
    Do NOT trust the temperatures that your motherboard's free temp utility reads. "PC Probe 2" that comes with Asus boards really sucks because it's not measuring your core temps. They are what you really care about.
    There are other temp monitoring programs out there. These are what I recommend.... I'll only mention one other by name with the advice that you do NOT use it: TAT (thermal analysis tool). It's made by Intel and I don't care what anyone else out there thinks: it was NOT designed to read the coretemps of a C2D/C2Q chip. It was written for Pentium M chips. Yes, it will display temps, and yes, sometimes they match up with the values Coretemp/HwMonitor display, but I have found that TAT often reports temps higher than the real values. How do I know this? Read this thread and pay attention to uncleweb's instructions to use crystalcpuid to directly read your DTS (digital temperature sensor) and calculate your core temp yourself if you don't believe me.
    BIOS Settings
    Let's look for some settings in your BIOS. Not all boards are the same. The following terms/pics are taken from my old P5B-Deluxe; other manufactures will likely have their own names for these settings. You're on your own to figure them out (shouldn't be that tough). It goes without saying that your board will have these organized differently as well.
    Lemme apologize upfront for the poor quality images below. I have no idea how to effectively photograph a computer monitor. I just used a cheap p&s camera with the lights off. You can still read them.
    First thing you want to do is change a few settings, I'll take them in order as they appear in the BIOS:
    Modify Ratio Support - disabled, but you can if you want to select a different multiplier. For the Q6600, 9x is the highest as I said. If you enable this, you can select a lower one if you want, some people think a lower multiplier and a higher FSB is better. For example: 9x333 = 3.01 GHz and so does 8x375. In my experience, doing this can lead to faster synthetic benchmark scores, but most real-world applications usually don't go appreciably faster.
    C1E – Intel’s so-called enhanced halt state. Read Anandtech’s blurb about it here for more. Disable initially, enable later on and see if the system remains stable. This is a power savings option.
    Max CPUID value limit – disable unless you’re running an older O/S like Windows NT.
    Vanderpool – disable unless you’re running VMWare or virtualPC; this option enables additional extensions within the processor that yields added acceleration when running multiple O/S’s on the same machine through virtual machines.
    CPU TM function – enable. Option affects CPU protection/throttle management to help you when you don’t realize you’re pushing your chip too hard.
    Execute Disable Bit - enable. XP has a setting to help with virus protection and requires this set to enable.
    PECI – This stands for Platform Environment Control Interface - disable or enable. This affects how your DTS (Digital Thermal Sensors) report the core temps of your CPU. I have mine enabled and have read several posts now that suggest having it enabled does indeed give more accurate core temps. I can’t say if you want it on or off in your system.
    According the Asus P5B-Deluxe FAQ, this setting toggles between two temp modes.
    Note: if you’re using a real core temperature monitoring application such as coretemp (mentioned and linked above), this setting has no effect that I can see.
    SpeedStep - Automatically lowers the multiplier from its max. (9x for the Q6600) to 6x when the machine is idle. The result is less power consumption and heat production. It goes back up to 9x when you start to get a CPU load. Disable initially, enable later on and see if the system remains stable. This is a power savings option.
    Why do you care about power savings? Increased power consumption translates into increased heat production. As well, power costs money and unless generated from a nuclear power plant, creates carbon dioxide gas. It’s true that energy savings will only matter when the machine is idle, but odds are your machine will spend most of its time at idle unless your run an app like fold@home or seti@home etc. Let’s assume for the sake of discussion that enabling these saves you 10 cents / day. A few pennies per day will add up over time. Using the dime-per-day as an example for a machine running every day is roughly a savings of $35 per year – not too shabby.
    Tomshardware.com's power savings article reported a savings of 12 full watts by enabling speedstep on their test system.
    Second thing you'll want to do is dial in the manufacture’s specs for your specific memory. Also take care not to exceed the design specs for your memory initially. We want to minimize the number of variables to deal with on a first time overclocking. In other words, if your machine isn't stable, you want to be sure it's due to the CPU settings, NOT the memory timings.
    Where can you get the manufacture’s specs? Try their website or the product packaging.
    Enter in the first four timings (4-4-4-12 in my case) and don’t mess with the default or auto values for the “sub timings” at this time. You can do that after you get a stable overclock.
    The only other setting worth mentioning here is the so-called “memory remap feature.” If you are running with more then 3 gigs of memory, and you want to actually have the BIOS/OS see it, you’ll need to enable this. Also enable this if you’re running a 64-bit operating system.
    Next, find the section where you can control the nuts and bolts of your system. On my P5B-Del I had to switch the AI tuning to "manual" mode to see these options:
    CPU Frequency - This is the FSB in MHz. Set it to whatever you’re planning to multiply by 9x (333 in my case).
    DRAM Frequency - This the speed your RAM will run. Make sure you don’t exceed the amount for which your specific RAM is rated.
    Most good boards will offer several fsb:dram dividers. Some common ones are listed below. Assuming that you’re using a 333 MHz FSB the ratios are:
    Code:
    FSB : DRAM
    1:1 = 333 MHz : 667 MHz
    4:5 = 333 MHz : 833 MHz
    2:3 = 333 MHz : 1,000 MHz
    5:8 = 333 MHz : 1,066 MHz
    3:5 = 333 MHz : 1,111 MHz
    1:2 = 333 MHz : 1,333 MHz
    Now, if you’re running @ a 400 MHz FSB, the ratios become:
    Code:
     FSB : DRAM
    1:1 = 400 MHz : 800 MHz
    4:5 = 400 MHz : 1,000 MHz
    2:3 = 400 MHz : 1,200 MHz
    5:8 = 400 MHz : 1,280 MHz
    3:5 = 400 MHz : 1,333 MHz
    1:2 = 400 MHz : 1,600 MHz
    You can calculate these yourself with this formula:
    Code:
    DRAM Final Clockrate = (2 x FSB)/Divider
    Example, 2/3 divider @ 400 MHz FSB: (2 x 400 MHz)/(2/3) = 1,200 MHz.
  2. graysky
    25 Mar 2008
    Running in 1:1 mode is termed, “synchronous mode.” If you use a higher frequency, you’re running is so-called “asynchronous mode” which offers marginal speed advantages at the price of more heat and power consumption on a C2D/C2D Quad-based system for most users. Depending on your chipset, running in an asynchronous mode may require more vcores to some of your motherboard components such as the NB, IHC, and/or FSB Termination (more on these later).
    PCI Express Frequency – Set this to 100 MHz. If you don’t, I believe the PCIe bus speed will increase proportionally with your FSB which is something you DON’T want to do to your expensive video board.
    PCI Clock Synchronization - Use 33.33 MHz here. Again, if you leave the setting on auto, the PCI clock will creep up proportionally with your FSB which can damage cards you may have there aren't designed to run at higher frequencies.
    Spread Spectrum - disable.
    Memory Voltage - Read the specs for your memory. My DIMMS can use up to 2.2v. You can damage your memory if you overvolt it.
    CPU VCore – THIS IS KEY! This single BIOS setting will have the largest effect on your processor’s operating temperatures! Again, read on to the section entitled, “Stress Testing and Minimizing Your Vcores.”
    It needs to be enough to run stable, but not too much or else you’re just wasting power and creating a ton of heat. This is particularly true with multicore processors!
    In case you’re wondering what Intel recommends for your processor, find your chip on Intel's Processor Finder. The Q6600 is between 0.85 – 1.5V.
    In my experience, a setting of “auto” ALWAYS over-estimates, but for your first boot, just leave it on auto. The next section of this guide covers stress testing whose goal is to verify stability and to minimize your vcore. For example, once you verify that you can run stable for several hours of stress testing, you'll want to come back and minimize this voltage until you become unstable again. Then simply add a little back. As you can see, my system runs stable @ 9x333 using 1.2625v.
    The last four voltages are also required to make a stable system. Leave them on auto for now. On my system, I lowered my chipset temps by about 4 °C by lowering them to the values you see in the pic.
    As I mentioned earlier, if you’re using high memory dividers (a.k.a. running your memory in asynchronous mode), you might have to manually tweak your NBvore and your ICH vcore to get the memory to run stable. For example, my Q6600/P5B-Deluxe system required me to up the NB vcore by +2 steps and the ICH vcore had to be set to the maximum value or else I couldn’t run my PC1066 memory at the higher dividers.
    My X3360/LT P35-T2R system on the other hand, didn’t require nearly that much extra to run in the 5:6 divider.
    In general, the P35 chipset is better than the P965 in this regard. I have read that the X38/X48 are on par or slightly superior to the P35.
    Okay, save your settings and hopefully your machine will complete the POST.
    If it doesn’t, and assuming you set your voltages to Auto, some common reasons are:
    • Memory voltage too low
    • Memory timings too aggressive
    • FSB too aggressive
    If you complete the POST, and make it into windows without a blue screen or reboot that's a good sign. Now on to the testing. Now that you're in Windows, load up CoreTemp or HWMonitor and have a look at your core temps when idle.
    They should be well under 50 °C unless it's REALLY hot in your room, see the end of this document for more on how ambient temps affect your CPU load temps. There are a number of things you can do to bring down your idle and load temps. Again, see the end of this guide for some suggestions.
    Let's stop here and figure out what the red-line for temps should be... for my B3 stepping of the Q6600, I don’t want to exceed a few degrees over Intel's 62 °C limit for any sustained period of time. The G0 stepping chip tolerates 71 °C, so you're probably safe a few degrees above that. You can decide on your own "red line" if you disagree with my admittedly conservative numbers. Here is some information you can use to help: Intel's Processor Finder. Read the Thermal Specification section. Wondering what the deal with the stepping of the chip is? Have a look at this article that will explain it as well as show you some differences between the new G0 stepping quads.
    I may be misunderstanding it, but as I read it, the thermal specs are the upper limit for the "case temp." No C2D or C2D quad processor actually has a sensor for "case temp" as defined by Intel. To measure this, you would need to place a sensor on the top of your IHS right in the center. C2D/quads have INTERNAL sensors (called DTS or Digital Thermal Sensors) but not external sensors. Some software and BIOS's can approximate this "case temp," but without a physical sensor there, you're just guessing.
    The formula for reading core temp from the DTS is:
    Code:
     Core Temp = tjmax – DTS
    Where DTS is the number the DTS is reporting, and tjmax is a constant (which differs with processor model and sometimes within a processor model based on its stepping)
    Note: There is no official communication from Intel as to the magnitude of tjmax for desktop/server C2D/C2Q chips! This makes calculating the “real” core temp tough since people are just guessing.
    For example, a Q6600 (G0) stepping may have a tjmax of either 95 or 105 (again, these are people’s best guesses). If tjmax is 105, then Core Temp = 105 - DTS. THIS DOESN'T MEAN THAT THE LIMIT FOR THE CHIP IS 105 °C! In this example, let’s say the DTS value is 50. Therefore, Coretemp = 105-50 = 55 °C. If tjmax is 95, the math becomes 95-50 = 45 °C. Don’t worry about doing this calculation; all the temp monitoring software will do it for you. I only mention it so you can understand what’s going on.
    I like to keep my core temps under 65 °C. I may be using a conservative number here, but I don't want to replace my chip anytime soon. If you don’t care about the longevity of your chip, you can likely use higher numbers. I have read about people running their chips right up to the factory shutdown/auto throttle down temp. It’s your chip, do what you want.
    Load up CPU-Z to see what your vcore is at idle.
    You’ll notice that the vcore in CPU-Z is different from the value you selected in your BIOS. This is normal and true for all boards. You’ll also notice it drops again when your machine enters a load state: again, this is normal and known as vdroop; some boards/chipsets do it worse than others. If you read at the end of the guide, some boards can be modified to eliminate or greatly reduce vdroop.
    The goal of stress testing is two fold:
    1) To arrive at a stress test stable system (>24 hours with no prime95 errors).
    2) To minimize your vcores and thus minimize heat product both on your CPU but also on your NB/SB and other MB components.
    Prime95 will run and every now and then it will check the values it’s calculating using your processor to its internal standards since its torture testing using known values. Assuming you enable error checking, you’ll be notified if your values differ indicating an instability. This is why it is IMPERATIVE that you enable error checking within Prime95; again, if you don’t enable it, you WILL NOT be notified of errors!
    Do so simply by going to the “Advanced” menu and enabling “Round off Checking.” If the system isn’t stable, it will report an error and stop stressing the core that gave the error.
    Now that you picked your operating condition (i.e. 9x333 or 8.5x400, etc.) let’s stabilize the system through stressing it with prime95. Just so you get an idea what to look for, Coretemp as well as Prime95 (double-check that you enabled round off error checking) and run the Torture Test>Large FFTs. You’ll wanna keep an eye on your system temps to make sure they don’t exceed the redline so the chip doesn’t get throttled (assuming you have thermal management enabled in your BIOS). All your cores should get stressed equally (look in the task manager to verify):
    For your reference, here’s what an error from within prime95 looks like:
    When/if you get an error (and you will), you’ll need to either back off on the operating conditions (FSB or multiplier) or add some voltage to your vcores. Therein lies the challenge. Since you have four different vcores to select from, how do you know which one or which ones to adjust?
    It’s now time to minimize your vcore settings. Reboot and go into the BIOS’ section where you can control your CPU and MB voltages. Remember, different motherboard will call these variables different terms. The pic below is right out of my BIOS so you can see what DFI calls them, and what they mean:
    CPU VID Control – The processor vcore, I’m not sure why DFI calls it “CPU VID Control” but whatever. From here on out, I’m going to call it Vcc since technically, the term VID is an entirely different concept (see this document, page 14 for more if you have an interest).
    DRAM – The memory vcore.
    SBCore – Southbridge vcore (might be called ICH in your board).
    NBCore – Northbridge vcore (might be called MCH in your board).
    VTT – Reference voltage (might be called FSB Termination voltage in your board). It’s used to terminate data lines between the MCH and CPU.
    Some motherboards give the option for GLT reference controls. If you enable this you’re adding three additional variables to the mix and making your life more complicated. Unless you’re an extreme overclocker wanting to squeeze every single MHz out of your system, my advice is not to enable the GLT options. I’d also caution you not to enable this option since there is tons of misinformation out there about these undocumented features.
    If you must, here a few links that might help you understand how it works and give you some starting points, but I won’t be using them in this guide:
    Adjusting [Advanced] Gunning Transceiver Logic (A/GTL+) Voltage Levels for Increased Front Side Bus (FSB) Signaling Margins and Overclocking.
    DFI UT P35-T2R: Tweakers Rejoice!
    Good thread (kinda long) but good info.
    There are several approaches you can use to arrive at a stable, minimized set of vcores. I recommend that you start with lower vcore values and work your way up. Lower values will fail much faster than higher values thus making the process a bit quicker for you.
    To start with, select a set of vcores that are kinda low and see if you can POST. How do you know where to start? Use trial and error at this point unless you know someone else’s settings to use as starting points. When in doubt, I’d recommend that you start near the bottom of the scale. Here are some rough guidelines for setting your VTT:
    1.2-1.3V - for a FSB of ~400 MHz.
    1.4-1.5V – for a FSB of ~420-440 MHz (exceed 1.4V at your own risk with a 45nm chip)!
    1.6V – for a FSB of ~440-475 MHz - use at your own risk with a 45nm chip!
    You should be aware that newer 45nm fab chips are MUCH less tolerant toward high VTT than their 65nm predecessors. Anantech published their experience frying a QX9650 with high VTT’s as an example.
    Vcc – Initially, set within 200-400 mV of where the auto setting used (remember that you need a little more in the BIOS compared to what CPU-Z told you). Remember to consult Intel’s processor finder to know where the upper-end of safety is for your processor (I believe the figures there correspond to the values CPU-Z is displaying, not what you set in the BIOS.).
    DRAM – What ever the RAM manufacture recommends is a good starting point. Unless you’re really overdriving them, they shouldn’t need more.
    SBCore – I’ve always used the lowest setting, but I typically don’t push my systems that hard (20-25 %). You’re on your own here.
    NBCore – Start off low, 1.33 or 1.37 and see if you need more. Also, a little bit can go a long way. My system is unstable @ 1.330V here but stable @ 1.370V which is a difference of only 40 mV (0.04V).
    Here are the levels my Q6600 @ 9x333 uses to run stable:
    Code:
    Memory Voltage=2.100V
    CPU VCore=1.2625V
    FSB Termination=1.200V
    NB Vcore=1.25V
    SB Vcore=1.50V
    ICH Chipset=1.057V
    Here are the levels my X3360 @ 8.5x400 uses to run stable:
    Code:
    Vcc=1.12500V
    SB 1.05V=1.070V
    NB Core=1.370V
    SB Core/CPU PLL=1.550V
    CPU VTT=1.310V
    I show those only to give you an idea, not all hardware is the same, and really, those values are personal to my chip, RAM (and RAM settings), MB, etc.!
    Once you select a baseline set, that will complete a POST, you’ll want to start a more vigorous evaluation by changing the MB vcores one-at-a-time moving forward. If you change too many variables at once, you’ll never be able to arrive at the stable settings. Confused? Don’t be, just read on and after you see the examples, I think the process will seem clearer to you.
    The basic process is to try different Vcc values keeping the other vcores constant. Run p95 at a given Vcc and record what happens after an arbitrary time point (10 to 15 min is good to start with). If Vcc level is stable for 15 min of p95, reboot and lower it a little and repeat. The goal is to find the minimum level that gives errors, then increase it until it’s stable, then extend that time out to say 2-4 h. If it’s still stable, further extend it to 10-14 h. You can probably call it “stable” if you can run p95 for 24 h. If a setting fails after 4 h, increase it one notch or so and repeat until it’s stable out to 24 h. You can then come back knowing this Vcc and try to lower one of the other vcores repeating the process. Yes, it’s time consuming and yes, it’s tedious, and yes, that’s a shitload of rebooting, but it works.
    The key to this process is keeping a detailed record to help you achieve a stable system and troubleshoot which vcore to change – p95 errors are NOT always the fault of a low Vcc! Without these data, you’ll have a tough time. So what do you keep track of here?
    1) The MB vcores you’re using
    2) The Vcc values you’re testing
    3) Which core failed (prime95 tells you) and how long it took to fail
    4) Any observations or comments you want to record for yourself
  3. graysky
    25 Mar 2008
    Here is an example minimizing vcores using my X3360/P35-based system. The data presented aren’t fabricated to help illustrate the method; rather, they are the real data I used to arrive at the stable system.
    Hardware specs for your reference:
    Before we dig into the examples, know that to really really do this right, you’d need to do several runs at the various levels; doing it just once as I am is the quick ‘n dirty approach and can cause you to draw an incorrect conclusion or two as you will see.
    On to it: in my first try, I set up my MB vcores and began testing Vcc starting low (I chose 1.12500V somewhat arbitrarily).
    Keeping the motherboard vcores constant, I varied the Vcc starting out low and working up high. You may or may not get a stable system on your first set of iterations (probably not actually). If you do, you’ll probably want to repeat keeping your stable Vcc but optimizing (minimizing) for one of the other vcores such as NB or VTT, etc.
    Code:
    Overclocking log, Iteration Set 1
    Comments: Initial try
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    VTT	1.200V
    Vcc/Prime95 success or failure
    1.12500V	Failed on core 3 ~ 5 min
    1.13750V	Failed on core 0 ~ 28 min
    1.15000V	Failed on core 2 ~1 h 18 min
    1.16250V	Failed on core 1 ~ 4 h 4 min
    Looking at the data, we see there that multiple cores have failed as I increased the Vcc. That’s suggestive of one of the other voltages lacking and thus needing to be increased. There are two likely causes for my instability: NBCore and VTT. In my next Iteration set (below), I chose to raise the NBCore several notches keeping the rest of the MB vcores constant.
    For discussion’s sake, let’s say the same core failed repeatedly. This scenario is likely caused by a low Vcc (although it doesn’t have to be). For you quad core users, cores 0/1 and cores 2/3 should be treated the same, so if you get some core 0 and core 1 failures, treat them like a single core failure as you consider this analysis.
    So, I increased the NBCore a few notches and tried a few higher Vcc settings just to see if it was enough:
    Code:
    Overclocking log, Iteration Set 2
    Comments: Added some NBCore
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.41V[/b]
    VTT	1.200V
    1.16250V	Failed on core 2 ~2 min
    1.17500V 	Failed on core 1 ~3 min
    Again, I got two quick failures across the entire chip. Ideally, you might want to collect more data points, but I took a hunch that 1.45V should be plenty for 8.5x400, and next added some VTT keeping the newer, higher NBCore constant – remember to only change one of them per iteration set!
    Code:
    Overclocking log, Iteration Set 3
    Comments: Added some VTT and kept the higher NBCore
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.41V
    [b]VTT	1.310V[/b]
    1.17500V	STABLE 15 min
    1.16250V	STABLE 15 min
    1.15000V	STABLE 15 min
    Now, with the higher VTT, I didn’t get a single failure for at least 15 min at the three Vcc values I ran. I concluded that the VTT gave me the stability. To test this hypothesis, I kept the higher VTT, but lowered the NBCore back to 1.37 and repeated in the 4th iteration:
    Code:
    Overclocking log, Iteration Set 4
    Comments: Kept the VTT, lowered the NBCore
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.37V[/b]
    VTT	1.310V
    1.15000V	STABLE 2 h
    1.13750V	STABLE 30 min
    1.12500V	STABLE 1 h
    1.07500V	crashed p95 (n=2)
    1.09375V	crashed p95 (n=1)
    1.10625V	BSoD after 1+h
    1.11875V	STABLE 11 h
    1.11250V	Failed on core 0 ~ 1 h 8 min
    Now I got some stable runs. After evaluating the data, I was able to nail down both my NB and VTT in only 3 iteration sets, arriving at what I thought was the stable Vcc in the 4th (I was later wrong).
    It’s a little easier to visualize if you sort the Vcc from low to high. If you keep your log in a spreadsheet, you can easily sort them, here are the same data sorted by Vcc:
    Code:
    DRAM	2.100V
    SBCore	1.55V
    [b]NBCore	1.37V[/b]
    VTT	1.310V
    1.07500V	crashed p95-program exited (n=2)
    1.09375V	crashed p95-program exited (n=1)
    1.10625V	BSoD after 1 h
    1.12500V	STABLE 1 h
    1.15000V	STABLE 2 h
    It would seem as though 1.11875V was the winner. I could have stopped right here and repeated extending the time out to 24+ h with these settings, but I elected to further optimize and targeted the VTT since I thought I could do better having jumped from 1.20 to 1.31 and skipping 5 sub levels in the process. This time through, I held the Vcc constant and varied, VTT:
    Code:
    Overclocking log, Iteration Set 5
    Comments: 1.11875V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    [b]Vcc	1.11875V[/b]
    VTT/Prime95 success or failure
    1.250V	Failed on core 0 ~ 2 h
    1.260V	Failed on core 2 ~ 1 h 20 min
    1.280V	Failed on core 0 ~ 18 h 22 min
    1.310V	Failed on core 1 ~ 1 h 20 min
    This one is a little puzzling since the 3rd run (VTT=1.280V) lasted for over 18 h, yet the 4th run with a higher VTT died in under 1-1/2 h. My thinking was that VTT wasn’t the problem, and that I had been mislead on the Vcc. I was also getting a little anxious for this to be finished and I broke my own cardinal rule for the next iteration set by upping two variables at once: Vcc to 1.12500V and VTT to 1.310V.
    Code:
    Overclocking log, Iteration Set 6
    Comments: 1.11875V seemed flaky, so upped the Vcc and kept the higher VTT.
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    [b]VTT	1.310V[/b]
    [b]1.125000V[/b]	STABLE 21 h 34 min
    Okay! So maybe it was the Vcc after all since it ran for over 21-1/2 h before I stopped it. You could argue that there’s no difference between 18-1/2 h and 21-1/2 h and you would have a valid argument. This underscores the need to collect multiple data point per level as I mentioned in the beginning of this section (I told you it was quick ‘n dirty)!
    Finally, I set out to essentially repeat my Iteration Set 5 minimizing the VTT with the slightly higher Vcc.
    Code:
    Overclocking log, Iteration Set 7
    Comments: 1.12500V seemed stable, minimizing VTT
    DRAM	2.100V
    SBCore	1.55V
    NBCore	1.37V
    Vcc	1.12500V
    1.250V	Failed on core 0 ~ 1 h 3 min
    1.280V	Failed on core 1 ~ 1 h 0 min
    1.310V	STABLE 34 h 41 min
    Apparently VTT needs to be 1.310V on this system. In any case, those examples should serve to illustrate the method you need to use to attack the task.
    To summarize, using a stepwise approach and documenting your runs, you should be able to arrive at a stable system (assuming your hardware can operate at the level you choice). It probably goes without saying that you will need to repeat this process if change your operating conditions (multiplier and FSB).
    An overclocked quad system is often limited by the amount of heat it’s producing, and the ability of the heat sink and fans to dissipate it. If you’re getting high temps, there are a number of things you can do to help. Most of them are hardware related but the first is the single most important non-hardware change you can make:
    • Minimize your vcores first (described in the guide above)!
    • Ensure good contact between the CPU and Heat sink is a must for efficient heat transfer. A major bang-for-the-buck modification in this regard is lapping the surfaces that transfer heat (the base of your heat sink and the top of your CPU). This involves gently moving the surface along wet/dry sand paper in increasing grits on a flat surface such as a piece of glass. I did both the base of my Ultra-120 Extreme and the IHS (Internal Heat Spreader) on my Q6600 and saw some pretty dramatic decreases in load temps.
    It should be noted that lapping your HS and/or CPU will void the warranty. Comparing my stock HS/CPU to my lapped HS/CPU, on average lapping lowered the coolest core by 7 °C and the hottest core by 10 °C. To read more about lapping your heat sink and CPU see these two threads; I have results and pictures of the process:
    Lapping Q6600 IHS
    Lapping the Ultra-120 Extreme
    That said my X3360 did not need to be lapped. I’m not sure if Intel is doing this with all their 45nm chips or just the Xeons, but it came from the factory very flat. When I run prime95, the heat spread between cores is 2-3 °C.
    • If your NB chipset runs too hot, consider adding a small fan. I put a silent 40x40x10mm fan on my NB HS via a zip tie which lowered my NB temps by ~7 °C on load. Pretty amazing effect for $3 fan and free zip tie :)
    • Consider an upgrade to a more efficient heat sink (like the few mentioned in the beginning of the guide). Remember that a quad core chip will produce about 2x the heat compared to a dual core chip. You really do need to consider using an extreme HS if you plan to overclock a quad.
    • Consider an upgrade to the cooling fan on the heat sink to something that has more flow. Most of the larger HS’s will use a 120mm fan. Some have the option for two fans. I think the fastest 120mm fan you can use is around 1600 RPMs. If you have a slower one, you might consider upgrading.
    • Reseat your heat sink and make sure you’re using a quality TIM (thermal interface material) such as AS5. Consider rotating the HS 90 degrees if it is designed to do so. I seem to get better contact with my Ultra-120 Extreme when it’s orientated “North/South” than when it’s orientated “East/West.”
    • Re-evaluate the way you’re applying the TIM/don’t use too much or make sure you’re using enough. Thermal pastes aren’t all created equally. Some are reported to be better than others. I have always used Arctic Silver 5 on my CPUs (and AS3 and AS1 before that). You can find all sorts of posts out there showing one to be better than another. I’ll leave it up to you to pick one. Again, I like AS5. Here is a shot of my q6600 installed in the MB with AS5 right before I added the HS. It shows the right amount in my opinion given a lapped HS and CPU (which is a thicker line than I used before); the red triangle I drew shows where that tag is on the CPU, remember that on quad core chips, the dies are placed in a different located relative to a dual core, see the instructions on AS5's website for more on this.
    • Use good cable management inside your case. Use twist ties or tie downs to bunch cables and keep them out of the way of airflow.
    • Make sure you have adequate airflow inside the case and make sure you’re using a well ventilated case. People often overlook this, but it’s important. Not all cases are designed for good airflow. I have an Antec P182 which is a great design. Make sure you have several exhaust fans and at least one intake fan. 120mm fans move more air than smaller 80mm fans do and also run much more quietly.
    You can see that my CPU load temps will increase/decrease as the ambient temperature fluctuates. Have a look at the following thread for details:
    Effect of room temp on CPU load temps
    Controlling vdroop
    Remember the vdroop you saw earlier? If you have a P5B-Deluxe (I believe this works on any of the boards in the P5B family actually), you can use a pencil to modify your board to minimize or fully remove this idle-to-load vdroop. Read the following thread if you want to do that:
    Get more vcore under load: vdroop pencil mod (pics)
    That's it for the guide. I hope you got some good info out of it and are able to successfully o/c your system as a result!
    mvagusta likes this.
  4. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Amazing...
  5. wyx087
    15 Aug 2007
    wow, really nice guide.
    the bit on temperature is a great read. now i know 72c is not my processor's MAX, it's the internals max. many thanks
  6. graysky
    25 Mar 2008
    Glad you guys found it useful...
    @wuyanxu - the jury is still out on the processor temp limit issue actually since Intel never published official data on what the Tjmax variable is actually for a given chip. Most the the temp apps out there including both HWMon and Coretemp make some assumptions about it. Realtemp is a new alternative. Unclewebb, the author, used a laser thermometer to measure the surface temp of him E8400 and based Realtemp off that. Have a look at that thread for more... I actually think that for my Q6600, 63 °C might be the max surface temp (in other words the cores can be hotter), but just how hot? I dunno and I'm not sure that anyone knows.
  7. Krikkit
    21 Jan 2003
    A great guide, but you can just use Orthos to load 2 cores at once rather than using Prime95. :)
  8. graysky
    25 Mar 2008
    @krikkit - but version 25 of prime95 loads all cores (2 or 4) with just one instance.
  9. nigelleg
    nigelleg What's a Dremel?
    4 Jan 2008
    Thanks graysky thats a great article that has answered so many questions
    Just interested to know (eg if going to a fsb of 333 for a 3ghz overclock) and you were using ddr2 800 and left your settings at 400mhz istead of lowering them to 333 what effect does this have to the overclock ?
  10. graysky
    25 Mar 2008
    @nigelleg - well, you can't actually run the memory @ 400 if you're FSB is 333. At least you can't on my board. Mine only supports the standard dividers. If the FSB Is 333 MHz they become:
    Code:
    1:1 is 667
    4:5 is 833
    2:3 is 1,000
    3:5 is 1,111
    1:2 is 1,333
    Your board may support 5:6 which would be 800. To answer your question about the effect, have a look at this thread which compares 1:1 to 3:5 @ 333 (667 vs. 1,111 using a 333 MHz FSB.) Doing realworld apps, I found about 2 % increase in speed from the higher divider, but it came at a cost: heat. I had to jack up several voltages to run that high and concluded that it wasn't worth the 2 % gain.
    If you have a look at
  11. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Thank you very much on submitting such a great guide.
    Any chance of detailing the pin mod's(Whatever the nane is) for the couple of LGA775 procs?
    i.e. Tracing two pads on my E6300 to get it to run at FSB1333 stock?
    And a comparison of over clocking at 1333/1066?
    (not specifically asking for myself, just in general)
  12. graysky
    25 Mar 2008
    @500 - I'll lap a chip, but I'm not willing to use a fine wire and connect two pins :) As I understand it, there is no reason to do such a mod if the board will allow you to alter the FSB. In otherwords, dial in 9x333 or 8x400, etc. Does your board not allow that?
  13. 500mph
    22 Jun 2007
    It doesn't always have to be a small wire. Conductive pins work great too.
    The motherboard I use for over clocking is just a 965 based board.
    I just think that running a E6300 stock@1333 then overclocking it would be a bit better that starting at a 1066fsb.
  14. EflfK
    EflfK What's a Dremel?
    13 Feb 2008
    Great guide taught me a lot as I'm just starting. What about those of us without the option of setting the PCI Express Freq to 100 Mhz. The only options on my board(D975xbx2) is Default and above starting with I believe 101.9 or somewhere around there.
  15. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    Bloody great guide, nicely done. Going to attempt to lap my X2 chip this week and see if I can push it a little further...
  16. graysky
    25 Mar 2008
    @EflfK - what's your default value? The important thing is to keep it from creeping up along with your FSB.
  17. cpemma
    cpemma Ecky thump
    27 Nov 2001
    You can check if your board holds a 100Hz default using GPU-ID (or similar) after a light overclock.
  18. EflfK
    13 Feb 2008
    The default value is in fact "Default" shown below from Intel's Bios Glossary.
    PCI Express Burn-in
    Mode
    • Default
    • 101.32 MHz
    • 102.64 MHz
    • 103.96 MHz
    • 105.28 MHz
    • 106.6 MHz
    • 107.92 MHz
    • 109.24 MHz
    Enables the selection of specific PCI Express clock
    frequencies.
    Warning: This setting is intended for validation and test
    purposes only. Altering clock frequencies may reduce
    system stability and/or the useful life of the system and
    processor. Operation at settings beyond component
    specification is not covered by Intel component warranties.
    If any problems occur during operation at non-default
    settings, reset the board to default values.
    I have searched for what this default value is with no success. Seeing as this is not "Automatic" will default remain the same regardless of the FSB?
    Will be able to check this tonight had a slight water cooling mishap and had to test run the pump for another 24 hours.
    My apologies if I should move this discussion to a separate post. Please let me know if I should.
  19. Dev25
    Dev25 What's a Dremel?
    26 Oct 2007
    Great Guide will help me soon
  20. NZ_mod_man
    NZ_mod_man What's a Dremel?
    26 Aug 2007
    I use both Coretemp and Speedfan for temp monitoring. Both of which read the same and seem reasonable @ 58°C load. I tried HWmonitor and it said that both my core temps where up at 85°C @ idle!!!!!
    What's up with that?
