News Gigabyte Z68 boards to use ‘virtual GPU’ software
Discussion in 'Article Discussion' started by arcticstoat, 6 May 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Interesting. Sounds a bit like nVidia's Optimus.
  3. c0ldfused
    c0ldfused What's a Dremel?
    19 Aug 2010
    Sounds like a great idea, I use my PC for surfing the net or watching movies but have a 560Ti for gaming.
    Could save money on the bills in the long run.
  4. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    But if everything is output through Sandybridge, does that mean having to use the motherboard video connection? Does that mean that you'll lose the ability to use multiple monitors?
    It sounds like a cool idea in theory, but I'll wait to see what it's like in practice before getting excited.
  5. thelaw
    thelaw What's a Dremel?
    10 Sep 2010
    Hybrid transitions between discreet graphics and the cpu/gpu graphics eh?
    I agree with the coments the biggest issue will to design the system to seem flawless when switching off discreet graphics cards when just in windows and them turning on when the system demands graphics processing powervwithout a time delay/lag...just sounds like a extra feature to charge more for a z68 board...
  6. Deders
    Deders Modder
    14 Nov 2010
    Quicksync?
  7. Guest-16
    Guest-16 Guest
    The ASUS Z68 boards can do QuickSync even if you plug the display output into the graphics cards because they have additional power hardware; it doesn't matter what output you use. AFAIK Gigabyte boards cannot do this. Hopefully bit-tech will test this :)
  8. TheStockBroker
    TheStockBroker Modder
    19 Nov 2009
    From the article: "The idea is that the software will take advantage of the media-centric capabilities of the Sandy Bridge PGU, which Intel claims is capable of encoding video faster and with less power consumption than mid-range discrete GPUs. This might sound unlikely, but it is plausible"
    Has Bit-Tech not yet done their own tests?
    Everywhere else is showing quite literally unbelievable encoding results.
    TSB
  9. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    This is the biggest "niggle" that affects Optimus. Users of the M11x R2 have noted many times where games simply refuse to use the discreet GPU instead defaulting the ingetraged one regardless of following the correct Optimus related procedures (adding the game to the "whitelist").
    Hopefully this won't affect the way this (Lucid logic) is supposed to work.
  10. azrael-
    azrael- I'm special...
    18 May 2008
    The way Virtu (and nVidia's Optimus/Synergy) works is by copying the content of the discrete GPU's frame buffer to the internal GPU's frame buffer. The problem here, as I see it, is that this may incur quite a substantial performance penalty. Although, if Virtu is a hit (and perhaps if Intel should buy Lucid or do their own Virtu), this process might move into hardware at some point.
    Oh, and regarding the Z68 chipset. I haven't really been able to figure out what all the commotion is. Z68 is the same chipset as P67 and H67 as well as all the other revisions of Cougar Point. The difference comes from which parts of the chipset are fused off and which aren't. It's called artificial market segmentation, and it's a game Intel just loves to play... :)
  11. TWeaK
    TWeaK Minimodder
    28 Jan 2010
    This. How will the GPU pass its display data to the system? Will it go back over the PCI-E connection? I know we're nowhere near saturating that connection, but it strikes me as pretty inefficient to have data shuffled around like that. Surely it would've been better to output whatever the Sandybridge PGU does over the discrete card.
  12. Bungletron
    Bungletron Minimodder
    25 May 2010
    I am an M11x R2 owner, as far as I am concerned the issue was fixed when the updated drivers were released last summer. As long as you are happy to add programs to the whitelist then I would say the Optimus system is flawless, cool and quiet doing running of the mill stuff, performance boost when discrete graphics are required, the transition is seemless.
    If this system works like Optimus it would be very useful. For example, I use 2 computers as a main rig and server, running the rig 24 hours is inefficient. If the discrete card was not used when not gaming then it would certainly be more viable to use one machine as gaming rig and server, I would cut my power consumption in half.
    I would hope that all video is routed internally (likely through the motherboard's video connector, which may negate its use in multi monitor setups as was mentioned). One thing I am unsure about is the mention of software, as far as I am aware Optimus is a hardware implementation for the most part, surely this is where the flawless and full performance transitions must come from. I fear any implementation in software would cause overhead and cripple performance, we shall see.
  13. dunx
    dunx ITX is where it's at !
    1 Sep 2010
    Be honest ! How many of you actually look at the power consumption ?
    dunx
    P.S. i7-960 + i7-870+ i7-870+i5-655K+Q6600....
  14. wyx087
    15 Aug 2007
    some Gigabyte boards doesn't have VGA output, most likely they just desoldered P67 returned, soldered Z68 and off it goes.
    so nvidia optimus (aka Synegy) won't work on these boards anymore, they require monitor to be pluged into the integrated VGA output. this press release is simply Gigabyte's way of saying "there, have some duck-tap to fix this issue we are too lazy to fix".
    using nvidia optimus for nvidia cards, and AMD's solution for AMD cards, are will be much better considering they already have strict game-driver test procedure.
  15. Hawkest
    Hawkest I got some 4GB new RAM
    22 Jun 2009
    i thought hydra wasn't as impressive as it was made out to be..... have lucid got this right?
  16. Deders
    Deders Modder
    14 Nov 2010
    I think that has more to do with multi GPU gaming performance, where there will be overhead translating the ATI and Nvidia driver code into something compatible with each other. I think with the Z68 implementation only 1 GPU will be used at once, for whatever purpose it's best for.
  17. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    is Z68 the x58 replacement?
  18. l3v1ck
    l3v1ck Fueling the world, one oil well at a time.
    23 Apr 2009
    I'd be interested in this as a way to save battery life on laptops, but on desktops it isn't an issue for me as I'd expect these boards to carry a slight price premium over ther standard boards without this technology.
  19. bobwya
    bobwya Custom PC Migrant
    3 May 2009
    Quite often since we had a new electricity meter fitted - which appears to actually measure our household usage (6 computer peak + various gadgets)... :-(
    I prefered the old meter which didn't appear to notice I was running a 4Ghz core i7 920, dual 2.6Ghz Opteron 270's, both with 8800GTX's and a HD array 24/7... Just about as inefficient (since the motherboard the Opterons are in doesn't support AMD PowerNOW! properly and the 8800GTX doesn't have a 2D low voltage mode) - as you can get!
  20. Deders
    Deders Modder
    14 Nov 2010
    Now and then I like to see how much power certain games and processes take up, Crysis 2 consistently draws the most for me, nearly 400w from the wall. Only the last Protos level from starcraft 2 came close.
Tags: Add Tags
