Storage Which F1 to go for?
Discussion in 'Hardware' started by Dr_Horse, 16 May 2009.
  1. Dr_Horse
    Dr_Horse What's a Dremel?
    25 Apr 2009
    Hey guys.
    I'm upgrading my main system hard drive this month. A couple of months ago PC Pro declared the 750gb model the king of the F1s so I'm looking at getting one. Did they get this right do you reckon?
  2. Jewels
    Jewels What's a Dremel?
    26 Apr 2009
    The 750GB model is technically the same as the 1TB model, with some of its space artificially disabled.
  3. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Can you buy a 750, and unlock it....?
  4. Dr_Horse
    25 Apr 2009
    Good knowledge, but does that mean it's quicker/slower/the same?
  5. trueno!
    trueno! That's TRUE-N-NO if ure not sure!..
    24 Apr 2009
    If you can stretch out for it I would go for the Samsung F1 HD103UJ HDD, I've had it for just under a month and it's been good so far... I've partitioned the drive into 2 and use the first partition for Windows XP and storing all my Anime on the second partition, and so far the drive hasn't done anything wierd...
    Here's a linky on ebay which is going for a good price! BUT, hurry there's not many left! ^_^
  6. alastor
    alastor Minimodder
    6 Sep 2004
    It's the same; has the same areal density, spin speed and cache, just only uses 250GB of each of it's 333GB platters.
    I'd go for the 1TB anyway, especially as it's going pretty cheap at Scan at the mo. No complaints with mine :D
    Edit: so cheap in fact that I've just bought another for some RAID1 redundancy.
  7. Dr_Horse
    25 Apr 2009
    Thanks for the responses guys.
    fyi it is cheaper at proper online retailers than that ebay link now.
  8. LeMaltor
    LeMaltor >^_^
    3 Oct 2003
    I've got the 1TB, it's perfect!
  9. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    I also have the 1tb and love it. Great drive.
  10. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    yet another 103 user here...
    I pile my Installs and Media on mine... but it's still quick enough to boot from (For most people) if you want to.
    It's scary how quick you can fill it up though (Linux Distro's stack up worringly quickly!)
    grab the 1TB, it's silly-cheap for what you get...
  11. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    the 1 tb is great, got the 750 gb one, but then the 1 tb came down in price, just after it was purchased.
  12. GK7
    GK7 What's a Dremel?
    2 May 2009
    Go for the 1TB. I have it in my HTPC and it's very quiet as well as quick.
  13. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    +1 for the 1tb version of the samsung F1. i have 2 of the 1tb F1's best choice i made i was looking at the 750gb one but got the 1tb for a good price so it was a no brainer really
  14. weeez
    weeez What's a Dremel?
    29 Apr 2009
    My F1 750gb goes like a rocket, just got a 1tb for storage so not sure if any difference in speed. Im guessing they're the same
    Scan has the 750 at £63 and the 1tb at £66, an extra 250gb for 3 quid?? cant complain at that!
  15. droitwichdosser
    droitwichdosser What's a Dremel?
    25 Apr 2009
  16. Slizza
    Slizza beautiful to demons
    23 Apr 2009
  17. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    The TB is faster, substantially. The way they cut it they reduce the platter density to 250Gb per platter. The 750Gb and 1Tb have 3 platters and the Tb is 334Gb/Platter
    The fast drives.
    Faster Drives ~115Mb/s MAX Read
    320GB ¦ 1 Platter ¦ 320Gb ¦ 16Mb Cache
    640GB ¦ 2 Platter ¦ 320Gb ¦ 16Mb Cache
    1000GB ¦ 3 Platter ¦ 334Gb ¦ 32Mb Cache
    Slower Drives ~90Mb/s MAX Read
    250GB ¦ 1 Platter ¦ 250Gb ¦ 16Mb Cache
    500GB ¦ 2 Platter ¦ 250Gb ¦ 16Mb Cache
    750GB ¦ 3 Platter ¦ 250Gb ¦ 32Mb Cache
  18. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    Where are those figures from?
    In the PC Pro hard drive lab last month the F1 750 GB was faster than the F1 1 TB.
    http://www.pcpro.co.uk/labs/252123/samsung-spinpoint-f1-1tb.html
    Maybe the 750 GB model has the inner part of the platter disabled, IIRC the outer part of the platter is faster?
  19. Madness_3d
    26 Apr 2009
    Sorry those figures are Max readings. I have compiled those results myself by running HD tune on the drives after a fresh windows install from machines at work. The 750GB I tested maxed out at 90Mb/s and averaged about 70Mb/s its possible that variance in motherboards has effected that there but as far as I am aware they cut off the inner area of the disk (which is the fastest part.) And TBH I wouldn't trust PCPro as far as I can throw them. I'd Much rather rely on the data that I personally have collected.
    Just Re-Ran My F1 1TB and got 116.8MB/s Max and 90.6MB/s average
  20. Turbotab
    4 Feb 2009
    I always though that the outer edge of the platter was the fastest, due to its greater circumference, can anybody give a definitive answer?
