does anyone know when Bit-Tech is going to be releasing there Review on the GeForce Fx i seen some pics on the forums but nothing as to a review.
At this moment in time mate they may not release an article at all, the way the nv30 is goin ul be lucky to get hold of one! [if the rumours r true] if ure looking for a new gfx's card and have money to spend then ur safest bet would be the ATi 9900 or perhaps the NV35! However if ur still gaggin for a review then check out tomshardware.com, theyve got a review with pics, but I wouldnt belive everythin u read there! note u may have to search for the article, it was called somein like Nvidia goes to hollywood! type those words in on the search and ul find it!! Hope that helps! !
koo yeah i was just wondering what Bit-Tech had to say bout it. Im not going to get it anyways Due to ive heard it and its to loud for me and i jsut dont wanna spend that type of money on one piece of Equipment when 500 bux or whatever can get my lots of kool pc stuff. i might go with the radeon 9700 pro im not sure yet cause thats a bit priced itself so im kinda stuck i burnt out my Geforce 4 ti4600 POS anyways didnt care much for it but anyways im running my GeForce 2 Mx 400 isnt a bad card runs pretty nice. well thanks for the site and if u got any other sites American $$ were i can get a Radeon 9700 Pro cheap let me know thanks
NNOOO!!!111 Blasphemer! Seriously, though. You might wanna check out Anandtech or [H]ardOCP. Some people are starting to question [H] as well though, so take their stuff with a pinch of salt. There are others, but I don't recall off the top of my head.
