New ZETA core
Discussion in 'bit-tech Folding Team' started by StreetSam, 28 May 2013.
  1. StreetSam
    StreetSam Minimodder
    30 Aug 2005
    Hi All,
    Well the new ZETA core has killed my PPD. My 450s have dropped from 12000PPD to 7500PPD, (the 650Tis have gone up from 16000 to 20000) and I have twelve 450s. So looks like it's time to dump the 450s and find something else, either;
    3x650Ti at;
    60000PPD
    192W 312.5PPD/W
    £300 200PPD/£
    or 2x660Ti at;
    120000PPD
    300W 400PPD/W
    £400 300PPD/£
    or 2x660 at;
    86000PPD
    280W 307PPD/W
    £280 307PPD/£
    or 1x670 at;
    71000PPD
    170W 418PPD/W
    £275 258PPD/£
    I quite like the 650s as they are quiet and cool. But I can't see past the PPD of 660Tis and they'll be sellable later as they are good cards for gaming.
  2. StreetSam
    30 Aug 2005
  3. johnim40
    johnim40 Minimodder
    23 Apr 2009
    i have 2 660s 1 @65c and 1 @58c 86k ish
    ok for gaming too
    £300ish
  4. Christopher N. Lew
    Christopher N. Lew Folding in memory of my father
    23 Apr 2009
    Do I need to use the v.7 client and/or Windows 7 to get these WUs?
  5. StreetSam
    30 Aug 2005
    Doc said he had the V7 client running on Linux I seem to remember. I don't know about the V6 client, but I just added "client-type beta" to the V7 client.
  6. johnim40
    johnim40 Minimodder
    23 Apr 2009
    me too
  7. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    If using the v6 client, then you need to use WINE - there are threads on the Forums of how to get GPU's Folding in v6, but trust me, it is far, far, far easier with v7 !!
  8. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    How do you get HFM.NET to recognise the new core?
    I'm getting zero ppd. :waah:
    Tnx.
  9. johnim40
    johnim40 Minimodder
    23 Apr 2009
    client-type beta" in the V7 client.
    then will auto update
  10. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    I already did that, but HFM.NET wont report PPD:
    Running 9% Q9450 & GTX460 Slot 00 Uniprocessor 00:13:14 0 (1.088 WUs) 20:04:14 Unknown 17 P8900 (R839, C0, G5) 0 49 0 scorpuk (35947) 01/06/2013 19:53 08/06/2013 07:53
    Click on link below to see HFM output.
    This is now the second unit its on and still 0 ppd
  11. johnim40
    johnim40 Minimodder
    23 Apr 2009
    i dont normally use it but just downloaded 0.9.1
    added v7 client
    then client name
    address
    password
    and it auto added my both 660s
  12. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    You running zeta core?
  13. johnim40
    johnim40 Minimodder
    23 Apr 2009
    yes on 2 x 660gtx and 1 x 560ti
  14. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    I guess mine doesn't want to play.
    Don't think I'm getting any better than non beta too.
  15. StreetSam
    30 Aug 2005
    You have to download the beta psummary "psummaryC.html" Then HFM.net reports the QRB just fine, as you can see from the link in my .sig (and Doc's)
  16. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    Ahh no I haven't.
    Where do I get that from please?
  17. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
  18. johnim40
    johnim40 Minimodder
    23 Apr 2009
  19. Scorpuk
    Scorpuk Minimodder
    10 Jan 2012
    I'm still not getting any work units for AMD and Linux. :waah:
    Maybe something do to with this though?
  20. DocJonz
    24 Apr 2009
    I'm running Core 17 on a number of machines - it's now under 'advanced'.
    However, having driver problems with WinXP when coupled with a GTX 780 - none of the 320.xx drivers appear to be stable for more than a couple of days :wallbash:
