Scratch Build – In Progress Epic PC Micron mATX - First Few Completed! 7th Nov
Discussion in 'Project Logs' started by Djayness, 15 Oct 2011.
  1. Djayness
    Djayness phwupupupup
    7 May 2008
    Here we go guys! I'm in a rush so the photos will explain :)
    We heard you like cases so we put a case in your case whilst you case.
    Still in the prototype phase, haven't polished all the logos down because I am waiting on the paint to dry!
    All will be explained soon!
  2. KiiYzOo
    KiiYzOo What's a Dremel?
    11 Mar 2011
    awesome! :D will you be bringing these to market too?
  3. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    this is briliant :D!
  4. OC Maximus
    OC Maximus What's a Dremel?
    7 Aug 2010
  5. Djayness
    7 May 2008
    Yes sir! This is just the prototype though, not the finished product by a long shot.
    Thanks!
    This is probably the last you'll see of this prototype, I have made quite a few changes and am starting again from scratch. The next version is the final going to my store.
    [​IMG] You need a lot of coolant to cool a CNC... There's 80AUD worth of coolant there!
    The case has enough room for two 350mm long graphics card. The HD6990 is 304mm if you were wondering :p
  6. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    One day I'll afford to use one of your cases for a build.
  7. KiiYzOo
    11 Mar 2011
    nice :) hopefully it won't cost too much :p
  8. Djayness
    7 May 2008
    This is one of my more affordable cases, it's 499AUD . Spent the last 5 hours straight on tweaking the current design on autocad, I think I've just about thought of everything now *hopefully*
    Then its back to the table to make the final finished product.
  9. KiiYzOo
    11 Mar 2011
    ummm, how much does it cost to make if your charging that for it?? looks awesome though :p
  10. Djayness
    7 May 2008
    The material cost for the single cell cast acrylic that goes into that case is well over 200AUD. The rest is just me paying the electricity and my time to cut, fabricate and assemble.
    Acrylic, good acrylic is not by any means cheap :)
  11. Warsmith
    Warsmith Enginseer
    5 Dec 2010
    :rock:Excited to see this. Subbed!:clap:
  12. DK63
    DK63 Resident magpie
    8 Sep 2009
    Will they be available in the UK?
  13. Hannes
    24 Apr 2010
    I have my eyes set on one of those big lamptron edition cases you've done. They're awesome and I'm really tired of small after my three builds. Hopefully they'll have the same quality as the two I've seen you done.
    This one looks great however! :)
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    No pictures here :waah:
  15. miahallen
    miahallen Team IRONMODS - World Champions!
    5 Sep 2010
    What are the external dimensions (WxDxH) ? Thanks, looks great :thumb:
  16. Djayness
    7 May 2008
  17. Cyril06
    Cyril06 paradyse.conception
    13 Aug 2010
    Really really nice !
  18. KiiYzOo
    11 Mar 2011
    how did you attach the main panels together?
  19. KoSoVaR^
    19 Dec 2010
    This is so great dude :), i hope that i will afford both of them!, but...why dont you implement dual120mm(240mm holes for an rad ?) inteo the micron case?
  20. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Damn, now I day-dream of a "micro" Micron case, without room for standard PSU, thicker walls and rounded corners for my carputer...
