Motherboards Any Asus m-itx or itx FM2+ boards due?
Discussion in 'Hardware' started by Harlequin, 17 Aug 2013.
  1. Harlequin
    Harlequin Modder
    4 Jun 2004
    Bindi ;) - think you might now this - as title - any FM2+ itx or m-itx board due (that dont catch fire!)
  2. teppic
    teppic What's a Dremel?
    18 Jul 2011
    I'd like to know when any of the FM2+ boards are due :)
  3. Harlequin
    Harlequin Modder
    4 Jun 2004
  4. teppic
    18 Jul 2011
    I've got a boardless A10-6800K so I'm wondering whether to sell it or wait for the FM2+ boards.
  5. Harlequin
    Harlequin Modder
    4 Jun 2004
    FM2+ will run that cpu nicely and you can stick kevari in next year ;)
    the audio on that sniper board looks really nice tbh
  6. teppic
    18 Jul 2011
    Yup that's exactly what I was thinking. I don't want to get an FM2 board now they've become obsolete.
  7. Guest-16
    Guest-16 Guest
    No AMD mini-ITX boards due sorry.
  8. penryn 2 hertz
    penryn 2 hertz I'm not a science fiction writer...
    10 Jun 2010
    But ASUS surely should know there is a big gap in the market for such a motherboard...
    Bindie maybe put a word in the ear of the cogs that turn at asus.
  9. Guest-16
    Guest-16 Guest
    Not my decision sorry. We have limited resource, just like we don't have ROG FM2+ boards as well.
  10. Harlequin
    Harlequin Modder
    4 Jun 2004
    ooooh gigabyte doing a sniper board but asus not doing a ROG?
    srsly though , the itx form factor would be a big miss :(
  11. Harlequin
    Harlequin Modder
    4 Jun 2004
  12. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    I'm sure JJ from Asus said there was an itx board coming on Linus Tech Tips live show. Maybe I imagined it... It would be nice to have an FM2+ itx board.
  13. Guest-16
    Guest-16 Guest
    Yea but which is the better, more trusted brand [because we never just make another board ROG colors] ;) Even MSI's gaming is more widely known than Sniper series :p
  14. Harlequin
    Harlequin Modder
    4 Jun 2004
    maybe - but at least gigabyte are making an itx board....
  15. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Asus made an AM3 ITX board in the past. Too bad you're not making one for the APU's.
  16. Guest-16
    Guest-16 Guest
    Update: Marketing is kicking up a fuss internally about making one. What features do you want and what kind of price range?
  17. penryn 2 hertz
    10 Jun 2010
    Space for a mini pci wireless card but antenna's present on i/o so you could add one when you like.
    Maybe the 24pin and 4pin power be mounted at an angle and sata ports so would make cabling look tidy-er.
  18. Harlequin
    Harlequin Modder
    4 Jun 2004
    decent vrm`s and caps - don't want a repeat of the asrock itx burn ups.
    sodimm slots chipset certified for 2133 ram - so it you wanted a shoe box sized A10 mini lan rig its doable , good quality sound would be nice but likely I think it`ll push the cost up - as would any `uber` features.
    I think (AS P2H said) - making it `cable tidy` and easy to add cables rather than any uber features.
    I suggested sodimms rather than dims is for 1 of space (although I see you use dims on your intel itx boards)
    edit:
    quite possiblty a middle of the road option similar to the Z87I-PRO.
    whilst not removeable it does have wifi with antenna header and the full on power option . but I think 10 usb on the back for a small stuffed in the lounge box might be too many so lose 4 of them and that clears space for better sound ;)
  19. Guest-16
    Guest-16 Guest
    Our WiFi GO cards fit within the I/O. It'll come pre-fitted. -n spec OK? US always wants .ac now but the cost upgrade is high.
    No chance on the right-angled pins sorry as there's nowhere near enough space and the fail-rate for the ATX connectors is massive. Frankly the whole power connectors on MB need to fundamentally change, but that's an industry-wide decision.
    VRMs: So it needs a daughter-board. That's immediately a 'performance mainstream' product cause that card is very expensive. [but also SO worth it like you say. Although a well-designed board will have OCP and OPP so it should just cut out to prevent catastrophic failure. That $0.5 part is a cost saving to some though..]
    There's no such thing as 2133 SO-DIMMs on the market sorry, and mini-ITX boards used to use SO-DIMMs but everyone bought full-DIMM boards instead. ;)
    A88X chipset has limited USB 3 ports unfortunately:
    AMD A88X FCH(Bolton D4) chipset :
    4 x USB 3.0/2.0 port(s) (2 at back panel, blue, 2 at mid-board)
    6 x USB 2.0/1.1 port(s) (2 at back panel, black, 4 at mid-board)
  20. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    I agree except having good audio is a must as you need the PCI-E slot for GPU usage and the point of a LAN box or SFF PC is to have it all in one box. Realtek audio is not good enough.
    Need:
    FAST RAM no need for SODIMM normal RAM is fine
    GB Ethernet
    WIFI? not really needed
    a mSATA 6GBs slot for mSATA SSD or Wifi card
    Good power chips and 24 pin+ 4Pin
    Decent sound chip atleast a Soundblaster, ausus if they produce any onboard chips or a TI as used in more USB DACs (Texas instruments) like in the Bering U-control is enough for onboard sound.
    All USB to be USB3
    a Star and reset button can be a cheap on, just for emergency testing.
