Scratch Build – In Progress [Project] Gas D3sk Build
Discussion in 'Project Logs' started by Gas_designs, 2 Oct 2014.
  1. Gas_designs
    Gas_designs Minimodder
    29 Sep 2014
    Hi boys, are just subscribed me, I want to also share with you my first Cross D3sk
    You excuse my English, use a translator....
    I am Italian :D
    I start with to bring the various measures of the cuts to do to the firm that folding.....
    Here the plate thickness 1,5mm :D
    I leave you to the first image. :thumb:
    ...... :thumb:
  2. Dragonith
    Dragonith What's a Dremel?
    4 May 2010
    I love desk mods, I'll sub see where you take this one!
    For now, all I can say is you do have quite a good drawing and cutting technique!
  3. Gas_designs
    29 Sep 2014
    It now touches to the central plate, that must be cut for being able to insert us the mortherboard::** :D
    Go with the holes::** :dremel:
    :thumb:
    I now insert the outdistance them some mortherboard::**
    These 2 aluminum plates will go on the part DX and sSX :hehe:
    ........... :thumb:
    Excuse my English. :rolleyes:
  4. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    looking good ,
  5. Gas_designs
    29 Sep 2014
    Ok I now start to cut out me the dividing panel in aluminum::** :D
    Now start to cut::** :dremel:
    .............. :clap:
  6. Gas_designs
    29 Sep 2014
  7. Cheapskate
    13 May 2007
  8. Gas_designs
    29 Sep 2014
    Continuous with to realize the windows forLCD ed SSD :hehe:
    Now the left side::*
    I now make the window for the dvd::*
    Same window on the left part::*
    ............... :clap:
  9. Gas_designs
    29 Sep 2014
    Ok, now trace the 3 holes of the anterior fans, where then I position there the grate from 360::* :D
    Down of handcuff dremel::* ::dremel:
    Et voilà :)
  10. Gas_designs
    29 Sep 2014
    I start with to fix the zone of the HD::* :D
    ........... :clap:
  11. Gas_designs
    29 Sep 2014
    Now in the back part of the Hd I position there her DCC :D
  12. Gas_designs
    29 Sep 2014
    I now pass to the other ledge after having marked well it for::*
    And I go to perforate::*
    I add some provisional gomminis::*
    It is fixed also the reservoir::*
  13. Gas_designs
    29 Sep 2014
    Now in the back zone, I make the holes for the fans.... here it will also go then us the radiator::*
    :dremel:
    Now make the same holes, but in the part of the plan of the reservoir, from where it will fish the fresh air::*
    :thumb: :thumb:
  14. Gas_designs
    29 Sep 2014
    Now comes the moment to make the holes for the passage of the pipes of the liquid::* :asd:
    I start with the reservoir::* :dremel:
    :dremel::clap:
    ................. :D
  15. Gas_designs
    29 Sep 2014
    Other aluminum plate to be modified :D
    And after a hour of job :dremel: :dremel:
    Rheobus::* ;)
  16. Gas_designs
    29 Sep 2014
    :D
    Today I have made a test climbing on the whole HW in the desk, to see if it were everything ok, and that there were no errors::* :gosh
    Then I have gotten off the everything, and I am ready to bring the reservoir in firm, for the dust sabbiatura of glass, and then a beautiful dust painting opaque black opossidica.... :asd
  17. Gas_designs
    29 Sep 2014
    Hello guys :D
    Today I have gone in firm to withdraw the Cross D3sk :clap: :clap:
    This morning to the job I was impatient to see..... :grr:
    ......... :jawdrop: :jawdrop:
  18. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    Wow! What a transformation.
    Part of me was hoping you'd keep the discoloured metal and just seal it - it looked very industrial/grungy, but the black looks great.
    Is it powder coated?
  19. Gas_designs
    29 Sep 2014
    Yes, dust painting :thumb:
  20. l3p
    l3p www.^.nl
    1 Nov 2010
    'Cross D3sk' :hip:
    I'm following :)
