Motherboards MSI P55-CD53 Intel P55
Discussion in 'Hardware' started by Silvershot, 5 Jan 2010.
  1. Silvershot
    Silvershot What's a Dremel?
    16 Dec 2009
    Hi there
    Following a previous post on an AMD build, I may decide to go the i5 route instead.
    Possibly the i5 661 if costs are right.
    Anyway, I can't seem to find many reviews on the mobo MSI P55-CD53 Intel P55 but thought it looked good and would like some opinions on it please?
    Attractors for me were, looks good, pci-e slot not too close to memory slots, cost.
    If anyone can recommend this or others in the same bracket, I would be very grateful.
    Note, this mobo has a handy function for overclocking, which I would rather use than manual as have zero experience and don't want to fry anthing! :D
    Thanks.
  2. Guest-16
    Guest-16 Guest
    I would avoid the CD53 and 45, the very few MOSFETs cannot handle overclocking and we blew up a board while testing for Custom PC recently.
    Look at the Gigabyte UD2 instead :thumb:
  3. mycopia
    mycopia What's a Dremel?
    25 Nov 2009
    Have you guys had a chance to look at gigabytes p55a's yet?
    any recomendations? am looking at price point of 120 quid and had kinda settled on p55a ud3r.
    any help/advice would be much appreciated !
  4. Guest-16
    Guest-16 Guest
  5. mycopia
    25 Nov 2009
    Thanks for the reply Bindi, although your omission of UD3/R is now worrying me (intentional or not) :)
    anyway i have a few weeks to decide, so a bit more reading up on the p55's seems to be my way for the moment.
    ps Silvershot apologies my friend for jumping on your thread, i hope you dont take it as a hijack!
  6. Guest-16
    Guest-16 Guest
    I cant remember the result of UD3R so I didn't mention it. :p
    We're answering Silver's question too so it's OK :)
  7. Silvershot
    16 Dec 2009
    Thanks for the replies. No worries mycopia, it's all good!
    Bindi, are there any issues with the proximity for the memory slots and PCI-E slot for GPUs? as they look very close.
  8. Guest-16
    Guest-16 Guest
    On what board?
  9. Silvershot
    16 Dec 2009
    Sorry, on the Gigabyte UD2.
    And how do they compare to their H55 versions?
