Well, this is gonna be a quick quick weekend mod. I already have my workstation up and when i looked at the Bitfenix Shadow i liked the shapes. So this little front panel mod is about combining the Bitfenix Prodigy and Shadow. Well, let´s go! My workstation right now Specs AMD A10 6800k 16gb GeIL EVO Veloce 2x120gb Intel 320 SSD VTX3D Radeon 7950 X-Edition Boost Custom watercooling, 240mm radiator in the top with Be Quiet! fans and red led 140mm fans in front and back. And here´s how it looked before i was tired of the front piece And the Bitfenix Shadow i got inspired by. The shape Right now... Fan controller will be lifted out to the same level as the new front panel.
Well, here is the rough shape. I may be putting in an angle in the lower part of the front also, dont know yet. Some filing and putty/bondo to do now! Almost burned my brain out getting this angles correct
Well, primer on. Some small surface sanding to do before final paint. (black). Dont know if i want the fan controller in the front either, just a high polished aluminium bitfenix logo.
99% done now, i put my fat fingers on the front piece, noticed it now when i packed away the camera, well... Flash on camera makes color diff bigger than its really are. have some re-aligning to do on the logo, and lower it a bit. Went with a brushed alu style on it Final pics soon, will take them daytime to prevent bad pics
Its hard to improve the looks of the Prodigy, but i like what you've done. Have you considered making the rounded parts of the case more angular to match the new front?
Thanks! Yeah, next step is to make something with the top to start with to match the new front piece Still in sketchup trying to figure out what yet
