Graphics If you had the cash would you go 770sli or a single 780ti
Discussion in 'Hardware' started by Kovoet, 30 Jul 2014.
  1. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    You guys who have had sli please advice add tonight I'm taking the plunge either way
  2. andrew8200m
    andrew8200m Multimodder
    4 May 2009
    A pair of 770s is great BUT go with the 4GB cards otherwise youll potentially hit vram issues AND the possibility of the cards running into sli profile issues.
    780TI ill avoid this
    780 6GB is probably a little pointless for most but can be a benefit on some games,
    I personally have a pair of 780TIs and shall be splitting them down to 2 single 780 ti systems as one is more than enough in 99% of games even at 4K
    Cheers
  3. Pete J
    Pete J Employed scum
    28 Sep 2009
    I'd go SLI 4GB 770s myself.
  4. RagingMadman
    RagingMadman What's a Dremel?
    6 Oct 2012
    As previously stated, there are games that demand performance and greater Vram capabilities.
    Metro last light is a prime example in which 4G Vram would be good but the SLI would be completely wasted as it doesn't support it.
    2 cards pose multiple issues in which a single card would not; greater power consumption, heat, profiles or lack there of, etc....
    Even having more Vram, I run into SLI issues with my GTX 780 3G setup.
    The real gains for SLI is price v.s. performance where SLI profiles are supported and supported well, as well as scalability in the future. You can always tack on another card for cheaper than buying the next best card that's released and see better performance. For Ex. go single 780Ti right now. Be big hoss for current titles and supported resolutions, and a gen or 2 down the road (800 series/900 series) buy another 780Ti and see greater gains. Run into the same issues as SLI'ing currently but still have the option of 1 780Ti v.s 1 770.
    TL;DR I would DEFINITELY go with the 780Ti
  5. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    Single 780TI.
  6. Nexxo
    23 Oct 2001
    If equivalent or faster in performance, a single card is always preferable over an SLI setup. Fewer driver issues, less power consumption, less heat.
  7. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    Get the best deal you can on a single GTX 780 Ti. I'm glad I went the single card route after previously playing with GTX 460 and GTX 670 SLI. Not because it was bad, quite the opposite! I really enjoyed playing around with SLI but now I'm playing more and more 'Early Access' games the lack of SLI profiles and benefits of a single GPU are becoming apparent.
  8. David164v8
    David164v8 Minimodder
    29 Aug 2011
    780 Ti. Performance will be great and in a few years when it isn't, add another cheaply.
  9. Teelzebub
    27 Nov 2009
    As Blogins says get the best card you can afford, forget about the very old argument about SLI driver problems yada yada some do have problems some don't personly I've never had a problem with SLI
  10. Kovoet
    26 Aug 2009
    Thanks guys. Read everyone and thinking towards the sli as I already have one 770.
  11. thetrashcanman
    thetrashcanman Angel headed hipsters
    18 Nov 2010
    Yeah ^ that get 1 of the best cards you can afford.
    Maybe sell your 770 and put it towards a 780ti?
  12. Parge
    16 Jul 2010
    The 880 is supposedly dropping at Gamescom. I'd hold off if I were you!
  13. Deders
    Deders Modder
    14 Nov 2010
    What resolution and refresh rate are you playing at?
  14. docodine
    docodine killed a guy once
    10 Feb 2007
    lol i had this same debate with myself a few weeks ago
    ended up with the 780ti
    haven't sold my 770 yet
    either sell the 770 asap to get maximum $ before 8-series details are out and buy a 780ti, or just sit on the 770 and wait for the 8-series cards
    @deders his monitor is in his sig, 2560x1080 @60hz
  15. Fizzban
    Fizzban Man of Many Typos
    10 Mar 2010
    780ti gets my vote.
  16. rollo
    rollo Modder
    16 May 2008
    780ti everytime
  17. Kovoet
    26 Aug 2009
    Right old man installing them tonight anything I should look out for
  18. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    Might be a daft question but I know very little about SLI (although going to try and pair up some 670s I bought to experiment with) so here it is:
    If you do by some chance have two cards in SLI and experience either issues or lack of support in some games, is there a way to disable one card just for that session? Or do you have to physically unseat it?
  19. Deders
    Deders Modder
    14 Nov 2010
    You can just run 1 card without removing it
  20. Blogins
    3 Aug 2010
    Disable SLI from the Nvidia Control Panel.
