What are the 5 apps you use the most or cant live without? Here are mine DISK CLEANER - www.diskcleaner.nl (Best TEMP FILE REMOVER i have ever found) REGSEEKER - http://www.hoverdesk.net/freeware.htm (BEST REG CLEANER I HAVE EVER FOUND (First time using it removed over 800 keys!)) Plus it does so much more..... MyIE2 - http://www.oldversion.com/download_Maxthon_0.9.27.html (BEST BROWSER I HAVE EVER FOUND (Uses the IE engine with an option for Gecko (Version 9.27.68))) RESTORATION - http://www3.telus.net/mikebike/RESTORATION.html (RESTORATION.ZIP (Best UNDELETE/TOTAL REMOVE program i have ever found)) DR. TCP - http://www.dslreports.com/drtcp (Excellent program to TWEAK your settings for faster speeds,etc)
just post this in here : http://forums.bit-tech.net/showthread.php?t=185481. Everything will be in the same place
Firefox iTunes AutoCAD '10 MPLab IDE DipTrace Hard to call the last one because there are a lot of circuit design tools that I use, but in terms of work, those are the top 5 that I use on an almost daily basis. [edit] I vote for this to be merged with the thread in Ghys' post.
yes but in the other thread, a simple description and a link are necessary. Otherwise reading 5 app names doesn't mean anything Plus, it should be about neat, unique underground apps, not firefox and itunes, which everybody uses
Quit Bitching Already ! Nah, you're probably right, but this thread is entitled "5 apps you love" and on a day to day basis, those are the 5 that I couldn't do without, give or take
since when did programs became apps? i prefer the world executable! Firefox.exe Thunderbird.exe Steam.exe mpc-hc.exe and....... explorer.exe
In which case: Soundconverter (All my music on my pc is .flac, my ipod wants .mp3s) Tuxguitar (Open source powertab and guitar pro reader/editor/player) BasKet (Note taking, copy and paste anything in here type app, kinda like Onenote) Kalzium (Hugely informative and wonderful periodic table, I'm a chemistry + biology undergrad) Unetbootin (Creates bootable OS' on a USB stick/SD Card)
Just off the top of my head: UltraEdit WinRAR CCleaner NetXfer PowerStrip I could easily add a few more...
