My brother recently broke the dfi rdx200 board on his pc. Now i have to upgrade. I have decided to put in a AMD Athlon II X2 240 processor. My question is whats the difference between the MSI 770-C45 and the MSI 770-G45 boards, since there is only a 3 euro difference between them, And will the G45 overclock as well as the C45? Any advice will be greatly appreciated Thanks
go for the asus M478-em or the pro much better overclockers and the EM will take ddr2 ram if you're still planning on using that from the old machine costs about £58
Thanks for answering so quick. I am ordering all my parts of www.komplett.ie This the only motherboard they had that resembled that was the ASUS M4N78 SE. Is this much the same?, Will i see much of a difference between ddr2 and ddr3? Thanks
ddr3 is much quicker but obviously you'll need a ddr3 board ,The board you're looking at is very similar but has 2 ram slot compared to 4 on the EM
is the ASUS M4A785D-M PRO similar to the M478-em? it seem to be pretty good as it is only 65 euro and supports ddr2 and ddr3 ram
