Hi guys im new around here but joined as it seems a much nicer group of pro modders & I reckon if anyone can give me any help or advice along the way? its you guys Im planning a new project for in the new year. just drafting out some idea's atm. but here is my rough draft before I get into the actual detailed design & all the exact measurements etc. its just a rough draft so still lots of details to add, but you get the concept. the chassis is a 2 frame design made all from aluminium there will bee 2x 360's in the side/front that exhaust & 3 fan intakes in the front. 240 in the top as exhaust disassembled pieces, the chassis will be riveted together & the outer skin screwed from the inside the res will be an acrylic up/midplate with 2x 70mm acrylic tubes that are cut down the centre & bonded to the mid/upright parts of the res. all the internal panels will be alu covering parts of the acrylic etc. now I do have all the tools to do it Calipers.... check CNC........ check Time......... check Money....... check Skills........ ????? wish me luck & any criticism or anything, or if you would change anything, pls feel free to leave any feedback or ideas. now to get that caliper rocking & start laying all this out into flat drawings & tweak/work out the bugs!
