I have one lying around from my sisters broken PC and I was wondering whether I'd get any sort of sensible PPD from this for the power it will use. I have no idea and I doubt any of you are using one but I guess every little helps, right?
With 96 cores and 268.8 GFLOPS I don't think it would be worth the power it would draw. Hopefully someone can be more helpful though
I'm going to go for it. Might as well until I can afford something far better, which will be never probably.
