Networks Need a new router... suggestions please!
Discussion in 'Hardware' started by phem0r, 14 Feb 2011.
  1. phem0r
    phem0r What's a Dremel?
    14 Feb 2011
    OK so I used to own a D-Link 2640B which was the most reliable router I've owned until it died
    So because I didn't want to be without the internet I went to the devil (pc world) and purchased a Cisco router. which turned out to be the worst router I have ever owned. It never seems to drop the actual internet connection but it always drop the network connection whether it's wired or wireless.
    Now I've never really been that up-to date on router tech so was hoping people could make some suggestions based on either experiences you've had or just opinions.
    I'm looking for a router that will be reliable and perform well... I play a lot of WoW and disconnecting half way through a raid boss because the router decided to loose its network is just driving me nuts :sigh:
    Thanks!
  2. phem0r
    14 Feb 2011
    Anyone?
  3. tehBoris
    tehBoris What's a Dremel?
    30 Jan 2011
    What's the model of the router you are having problems with?
  4. The Monk
    The Monk Minimodder
    15 Dec 2010
    I have recently had to buy a new router as our old one would drop connection, or need to be restarted several times to even get a connection. I plumped for a TP-Link TD-W8950ND as they had good reviews and it was a very reasonable price.
    Had it for just over a month and haven't had a single problem with my connection, it can have two laptops(connected via wireless), a desktop pc and a couple of smartphones connected all at the same time. Can't fault it at all :D
    http://www.amazon.co.uk/TP-Link-TD-...1_1?ie=UTF8&s=computers&qid=1297721132&sr=8-1
  5. law99
    law99 Custom User Title
    24 Sep 2009
    It was Linksys???
    I had nothing but problems with those Linksys products. I've never been happy with any router though.
    I want traffic shaping. Is there a cheap router with traffic shaping that's any good?
  6. sourdough
    sourdough Minimodder
    17 Sep 2010
    I have been using a DLink DIR-855 for a few months now, have 2 wired pcs, 1 wireless, 1 voip phone and a Buffalo 1Tb Linkstation connected using 2008 firmware. No problems so far.
  7. Cus_de_Sparta65
    Cus_de_Sparta65 "There is no dremel"
    24 Apr 2009
    Bought a NETGEAR WNR1000 RangeMax 150 Wireless Cable Router the other week and it has been really solid.
    I download a lot of video as I do not watch TV any more. In my old age I am becoming quite cantankerous and hate the thought of some programmer deciding which shows to watch and when!
    Getting great speeds via wireless
  8. tehBoris
    30 Jan 2011
    If you want proper traffic shaping you really need a computer to do it. Routers while quite powerful really don't have the power necessary for proper packet inspection and prioritization.
  9. padrejones2001
    padrejones2001 Puppy Love
    17 Jun 2004
    WNDR3700. Best router I've ever had.
  10. Guest-16
    Guest-16 Guest
    http://techinstyle.tv/blogs/asus-rt-n56u-dual-band-is-better-and-heres-why/
    N56U will do it. I talked to the PM, he claimed it uses a CPU twice the spec of most of the industry. Shame they didn't advertise that fact :duh:
