Hey, Suddenly my 460 has halved its core and shader speed, dropping it PPD to 7.5K And I can't seem to get it back to normal speeds? Any ideas? Thanks
Not sure if it was the cause but this sometimes follows a failed wu. Normal procedure is to reboot to get back to full speed. It could have just been a bad wu but if it happens again you should improve the cooling or drop the overclock a little. Edit: 7.5K ppd seems pretty high for a half speed 460 running the current batch of projects. What wu is it running and what ppd does it normally get on that wu?
Sorry, its 5.7k, not 7.5k, thats my total Running a 6800, normally gets around 11k Ok, I'll reboot then, no idea if it was a bad wu
