Scratch Build – In Progress A Simple Case of Cu Al ( not sponsored )
Discussion in 'Project Logs' started by Teelzebub, 15 May 2015.
  1. Teelzebub
    27 Nov 2009
    I decided I needed a better more powerful computer for the CNC, So I thought why not let the CNC do the work then :)
    Anyway the parts are as listed below
    Motherboard Asrock H61 MV-itx 1155 socket
    CPU intel 2500K
    HDD Seagate 750g Hybrid
    The rest is still undecided atm
    So to start a pic of the mobo and some sheet metal
    Instead of endless renders here's the CNC software picture
    Before
    And after
  2. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Go on mate, what you got stashed in your bag of tricks for this? :D
  3. Teelzebub
    27 Nov 2009
    I have many things in my bag :naughty:
  4. Cheapskate
    13 May 2007
    I only have two things in my bag.
    That scribble on the plate doesn't have a single 90degree edge. I like that.:D
  5. Nexxo
    23 Oct 2001
    I'm now waiting for when you decide to build a bigger house to put the CNC in. :p
    Gratuitous CNC action:
  6. Teelzebub
    27 Nov 2009
    Correct :thumb:
    Na I'll just remove some more walls :hehe:
    Well side two today and two of them too lol just read that
    Anyway this is what the CNC was doing on the reverse
    So we end up with a 3mm recess on this side around the hole.
    And a 2mm deep grove around the other side
  7. Waynio
    Waynio Relaxing
    20 Aug 2009
    Watching. :)
  8. BeeP
    BeeP Minimodder
    17 Dec 2009
    Are you machining that without any fluid?
  9. Teelzebub
    27 Nov 2009
    Of course I'm using cutting oil/coolant cutters wouldn't last long without it
  10. Cheapskate
    13 May 2007
    Looking good.:D
    Is that groove a perfect fit for one of your metal trash cans, or do you have other plans?
  11. Teelzebub
    27 Nov 2009
    Oi you, you calling my work trash :grr::grr: lol there's a purpose for them :thumb:
  12. David
    7 Apr 2009
    Yay, it's about time the devil made work for his idle hands! :p
    Assuming those two plates are going to be end caps, is the centre section going to be tube-like in appearance? :cooldude:
  13. Teelzebub
    27 Nov 2009
    They are either side of the case with feet .
  14. bulldogjeff
    2 Mar 2010
    Ah ha the beast is finally doing some work, so is the CNC lol
    Looking forward to see where this one goes.
    Off to a nice start Tel.
  15. Teelzebub
    27 Nov 2009
    When you going to start that project of yours then Jeff
  16. bulldogjeff
    2 Mar 2010
    Been waiting on you mate :D
  17. Teelzebub
    27 Nov 2009
    Don't leave it to long then mate
  18. Ocelot
    Ocelot Minimodder
    4 Apr 2013
    Promising start. looking forward to more. Had to smile when I read the 'not sponsored' tag.
  19. Teelzebub
    27 Nov 2009
    A small update I cut out one of the side panel inserts from some 3mm copper plate.
    Cuts easy
    Fits perfectly
  20. bulldogjeff
    2 Mar 2010
    It seems every build on here is sponsored these days.
