Storage Sata: Size vs Speed
Discussion in 'Hardware' started by 00parrys, 16 Jul 2010.
  1. 00parrys
    00parrys What's a Dremel?
    11 Jul 2010
    Hi guys,
    I am planning a new build, and have already decided on the motherboard, which happens to be sata 3 (6gb/s) compatible. Now, I have been offered a cheap 1 TB drive new from a friend, only it runs at sata 2 speed (3gb/s). I have a limited budget, so the choice is between the larger 1TB drive at 3gb/s, or spend a little more and get around 500gb using sata 2.
    So, any thoughts? Do applications normally saturate the sata 2 speed anyway? Will having a "faster" HDD actually translate to a performance improvement?
    I figure it's best to go with the larger drive, and then later on get an SSD for a boot drive when they drop in price.
    Cheers,
    Sam
  2. adam_bagpuss
    24 Apr 2009
    do you mean SATA3 aka 6Gb/s im guessing so.
    mechanical HDDs do not benefit from this at all as they dont even saturate SATA2 (3Gb/s)
    Best mechanical drive is a samsung 1TB F3 if you can get that a samsung F3 500GB is like 95% as fast.
    beware not all HDD are the same so a cheap 1TB HDD may in fact be an old one and be slow.
  3. roosauce
    roosauce Looking for xmas projects??
    12 Feb 2010
    Mechanical drives don't saturate SATA 2. The only drives that take advantage of 6Gbps are some of the faster SSDs.
    You are definitely better off with the larger drive ... then move to an SSD boot drive when you can.
  4. 00parrys
    11 Jul 2010
    Awesome, I will get the 1TB, sata 2 drive then.
    @adam_bagpuss: Funny you should say that about the samsung drives, as the one I've been offered is here because it's on a deal on scan if you buy two.
  5. roosauce
    12 Feb 2010
    That's the good one alright ... I have one on the way. It's pretty much the best mechanical drive you can buy right now.
  6. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    Well, unless you're including (most) 15K enterprise drives (well my Seagate Cheetah 15K.7 SAS drives are significantly faster on most r/w benchmarks & irl than the F3s) or, since sequential r/w isn't the be all & end all of how fast a drive is, you ignore random access times & iops where the Velociraptors tend to win out.
    Having said that, the F3s are decent drives for the money (& own 4 few myself).
  7. roosauce
    12 Feb 2010
    'best' not 'fastest' :) Although it does pretty well for sure.
