Case Mod - In Progress Simple
Discussion in 'Project Logs' started by GotMod?, 30 Jan 2014.
  1. GotMod?
    GotMod? What's a Dremel?
    3 Apr 2012
    Hi everyone!
    After some pause, I have a new worklog.
    Nothing extraordinary, simple project with some moderate modding.
    Components are pretty basic for this project:
    AMD A10-5800K
    ASRock FM2A85X-ITX
    Scythe Big Shuriken 2 rev.B
    Corsair Vengeance 8gb
    SSD Corsair 90gb
    SilverStone SST-ST50F-P 500W
    SilverStone SG05
    I'm, probably, gonna use it as htpc/home media center/web surfing or will take to my office )
    So, let's start with some photos:
    Memory installed:
    Some fan pics:
    PSU,
    i know it's too overpowered for this project, but i had this psu lying around, so gonna use it anyway
    Started to do some actual work:
    Removed all the stickers from MB ))
    Placed CPU
    Also did some painting job on MB:
    Used white car paint marker. Result is pretty good.
    I really didn't like the black color of cpu fan and it didn't match the color scheme of the project.
    So, painted it:
    Did some sleeving, but it is not perfect - gonna redo it later, when will sleeve my PSU
    The white spots on the blades are from flashlight.
    And here is the result. I'm satisfied.:rock:
    to be continued...
  2. Shurika
    Shurika Minimodder
    9 Mar 2012
    Looking good, bro ;) love the colour scheme
  3. GotMod?
    3 Apr 2012
    thanx, man!!
    Time to paint PSU:
    Some coats of primer:
    And done:
    more to come...
  4. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    I shouldn't scroll so fast - I saw mini-ITX board, Blue painted fan, then PSU with blue painted fan and thought you'd somehow fit the whole thing into the PSU case!
    Looking interesting (now I read it properly), what kind of layout are you thinking of?
  5. GotMod?
    3 Apr 2012
    :D that would be a nice idea for another mod :dremel:
    Little update.
    SilverStone SG05:
    And some modding. Used old lian li feet:
    Here is what i'm thinking of the layout.
    I'm gonna place psu in the front of case, using holes for a stock front fan.
