Motherboards Motherboard driver
Discussion in 'Hardware' started by Deathwalker1701, 26 Apr 2014.
  1. Deathwalker1701
    Deathwalker1701 What's a Dremel?
    14 May 2009
    Hy there I've reinstalled windows 7 but cant find my motherboard drivers.
    on the motherboard it say p8p67 pro rev 1.01 and it's a asus board.
    problem i can't find that rev in there support section.
    Also i only have internet through my laptop.
    so any help would be great
  2. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    The particular revision of the board doesn't matter too much. Use the drivers here for your board.
  3. TheMadDutchDude
    23 Aug 2013
    As above. The revision does not matter. :)
  4. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    Depending on the OS you choose, those drivers vary as to how ancient they are.
    The best site i've found for a unified approach for keeping a mobo's drivers up to date is Station Drivers - your board is here.
    in addition to that, you 'might' want to try a modded bios to get the latest intel orom as Asus stop updating their bioses after a while - see the info here...
    ...though the primary reason for doing this is if you want to run SSDs in R0 & have trim.
    (simply because, i've used the modded ones for my p8z77-v pro & premium boards for around 9-10 months now & i've never had an issue)
  5. Deathwalker1701
    14 May 2009
    Thanks for your help just stuck on one driver witch is 802.11 wlan.
  6. PocketDemon
    PocketDemon Modder
    3 Jul 2010
    i think the latest WHQL version is 17.0.1.5...
    (i've linked to the main page for the intel ProSet drivers as that's where any updates would appear - so it could be bookmarked)
    ...clearly Station Drivers has the wrong Wi-Fi controller for some reason on the mobo's page.
  7. Deathwalker1701
    14 May 2009
    I could not get downloads for your link to work but i manage to find them someware else.
    but dont seam to be the right ones.
    im going to my mums tomorrow ive think i got a dongle there
    I can use that to get back on line and use a update program.
    ps thanks for the help
