News AMD makes a fresh start with graphics software
Discussion in 'Article Discussion' started by Dogbert666, 2 Nov 2015.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. theshadow2001
    3 May 2012
    To be honest, CCC was something that could have done with a make over and rebranding like this. If you compare the aesthetic of CCC to GeForce Experience CCC looked really dated and old. to be honest I think this still falls short of Experience.
    Whilst the look of a piece of software doesn't matter in any real terms, like it or not, it will have an affect on brand image and it will affect sales. We aren't as impenetrable to advertising and marketing as we would like to think.
  3. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    I think AMD is doing to CCC what Microsoft did to IE: the important part of the software code will largely remain the same, but they want to remove the stigma that the old name carries, so they intentionally change it up enough to not look or behave like the old software and just slap a new name on it. Of course, I could be wrong about this, it's really just a speculation. I don't know enough about Edge or Radeon Software to know how different they really are from their predecessors.
  4. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    In the Paragraph above the embedded video, last sentence, horse's mouse?
  5. Dogbert666
    17 Jan 2010
    Lol. Fixed. Thanks!
  6. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    No. Just no. Let's have some proper English rather than made-up weasely PR speak please :)
    I remember when CCC first came out, it got a lot of stick because ATI had decided to write it in C# - they took a lot of flack from idiots who confused the CCC settings app with the actual drivers, and thought it was the drivers that were written in C# :sigh:
    To be honest, I'm not overly fussed about the look of the software, but if the new version is easier to use than CCC then I'll be a happy man.
  7. theshadow2001
    3 May 2012
    If it is written in c# previously and is in Qt now(a C++ GUI API), then it should be a much more cross platform friendly program.
  8. ----jimbo----
    ----jimbo---- What's a Dremel?
    15 Jul 2009
    Basically you issue your opinion as fact then end your message with the fact you don't really know. Edge uses a completely new engine over IE and shares very little code.
  9. theshadow2001
    3 May 2012
    Oh the humanity! :rolleyes:
    According to WikipediaEdge's display engine is a fork of the one used in Internet Explorer. So its hardly that new is it?
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Aye, "re-architected" is absolute cobblers. Even "re-architectured" is better, although it's still absolute cobblers. What's wrong with "redesigned"?
  11. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Re-designed means the design was changed. Re-architected means the software architecture was changed. Ditching .NET for QT is a pretty big architecture change.
  12. PaulC2K
    PaulC2K PC Master Race
    14 Apr 2004
    If the announcement is a big deal, "redesigned" is probably just fine.
    When the audience is likely to think "oh, okay... you wasted my time just to tell me that?" then you need "re-architected" to make it sound a little more impressive.
    That's PR 101.
  13. wst
    wst Minimodder
    30 Aug 2009
    I'd've gone with "restructured". It's a real word and isn't just a new façade but actually some load bearing members and joists had to be moved about and suchlike on the inside.
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
  15. theshadow2001
    3 May 2012
    I doubt it. One of the few assets AMD have left is good will and a move like that would annihilate it. Its not their style anyway, AMD don't lock things out the way Nvidia does. Mantle -> Vulkan. OpenCL is used as their compute platform. Compute power is not nerfed the same way as Nvidia does with their GeForce GPUs. NVidia drivers won't allow GeForce cards to work when passed into a VM where as AMD cards work fine. Freesync uses an open standard, Nvidia won't even look at supporting display port extension (unless its in a laptop).
  16. Xir
    Xir Modder
    26 Apr 2006
    a thorough "meh" from me,
    I prefer just the driver, not the software suite. CCC has been a self-installing pain for years.
  17. Assassin8or
    Assassin8or Minimodder
    24 Apr 2009
    I guess that you don't have dual graphics cards and triple displays then? :-D
  18. Horizon
    Horizon Dremel Worthy
    30 May 2008
    Yes it was forked but do you even know what forked means? As he has stated he can be entirely correct as it can share some very basic code and the rest be entirely new, making it a distinct and new engine.
  19. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    Is it still as ****-slow and useless as CCC?
  20. Flibblebot
    19 Apr 2005
    The biggest problem I have is that "architect" is a noun not a verb: it literally means "chief builder". I hate the habit of turning nouns into verbs - and you can get the same level of importance by using the term "re-built" without having to make words up. :sigh:
    Getting back to the topic, ATI drivers have always appeared second-rate compared to nVidia's. I don't know whether it's their release rate or the look of CCC compared to nVidia's offerings and rate of release, but it's always seemed to me that ATI aren't quite as dedicated to the gamer as nVidia are. That's my perception, anyway.
Tags: Add Tags
