Case Mod - In Progress Acid Veins - Cosmos S (Water Cooled, Dual Loop)
Discussion in 'Project Logs' started by mac1as, 14 Dec 2010.
  1. mac1as
    mac1as Acid Veins
    14 Dec 2010
    Hello to all Modders maniac, I'm new on forum and want to show You my project worklog:
    code name: >> Acid Veins <<.
    Main Components:
    DFI DK X58-T3eH6
    Intel i7 920
    OCZ 6GB PC312800 CL7
    HD R5850 + GeForce 9600 GT
    SilverStone Strider 1000W - ST1000
    WC Components:
    EK Water Blocks EK-CoolStream RAD XT 240
    EK Water Blocks EK-CoolStream RAD XT 360
    2x Laing DDC-pump
    EK-BAY Spin Res DUAL Loop - Black Acetal
    "Veins" 10/13
    EK Water Blocks EK-Supreme LT Acetal+Nickel
    NB - EK Water Blocks EK-NB/SB 5 Acetal
    EK Water Blocks EK-FC5850 Acetal + Nickel + EK Water Blocks EK-FC5850/5870 RAM Backplate - Black + EK Water Blocks EK-FC9600 SLI - Acetal VGA Block
    MIPS RAM cooler 5 incl. 3 RAM Module Nickel POM Limited Edition
    2l Thermochill EC-6 Clear 1000ml + Mayhems Dye
    Other Components:
    1x AquaComputer Aquaero
    2x Lamptron Fan-Atic: 5-port
    7x 120mm Enermax Magma (Green)
    3x 120mm Scythe Kaze Jyuni Slip Stream 120mm Fan 1900 RPM
    All closed in Cooler Master Cosmos S.
  2. mac1as
    mac1as Acid Veins
    14 Dec 2010
    On the begining I want to apologise for my english, it isn't my primary language so please by tolerant, I won't be writing much instead of that I will try show more pictures.
    How Cosmos S looks everyone know so I will skip showing it and start from naked pictures of case:
    Hole for 240 radiator on bottom:
  3. Mattmc91
    Mattmc91 Minimodder
    18 Oct 2009
    use image tags such as
    Code:
    [img] [/img]
    around your links, saves people clicking them each time.
    edit: on topic, nice cuts on the bottom ;)
  4. mac1as
    mac1as Acid Veins
    14 Dec 2010
    Rivets removed, case in pieces, many pieces ready to powder coat (black matt):
    Visit in powder coat workshop:
    couple minutes in furnace:
    and we have it:
    OK with pictures now?
  5. bulldogjeff
    2 Mar 2010
    Off to a good start:thumb:
  6. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    Pictures are perfect now, lookin' really nice so far.
  7. mac1as
    mac1as Acid Veins
    14 Dec 2010
    Putting case back together:
  8. infekted.one
    infekted.one What's a Dremel?
    7 Nov 2006
    Nice rivets!!! :eyebrow: (that's got to be geek innuen:hip::eyebrow:do...)
    Nice thorough work, what's your plans?
  9. mac1as
    mac1as Acid Veins
    14 Dec 2010
    Hmmm, it won't be anything special, visit my worklog sometimes and You will see.
    Back to rivets:
  10. mac1as
    mac1as Acid Veins
    14 Dec 2010
    OK time to move on, fan mode:
    Under UV light:
    Few small case moddifications:
  11. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really nice and clean mod my friend, the attention to detail it will pay u out at the end! :) Mod on!
  12. KidMod-Southpaw
    28 Sep 2010
    This is fantastic, so are the fans, so are the LED's. Mod on!
  13. ThirtyQuidKid
    ThirtyQuidKid Minimodder
    11 Jun 2010
    This is looking great. Should be a great finish to it.
    p.s. I especially like the use of plasticene!!!!! I would never have thought of thaty and probably used some expensive resin based putty and tried to dye it without sucess.......
    Good work.
  14. mac1as
    mac1as Acid Veins
    14 Dec 2010
    Thank You guys for good words.
    Here You can see pump mod:
    And some sleeving:
    Sleeving could be better.
    Cable menegment mode:
    My hands was bit shaking and its not like it should be, but it not so bad.
    Switch for UV Cathodes:
    Block for GeForce 9600GT to PhysX:
    and after nickle plating:
    Mobo I/O Backplate & GFX slots after powder coating:
  15. KidMod-Southpaw
    28 Sep 2010
    What can I say, delicious! That's one hell of a cable management system for the 24 pin.
  16. Mizakoto
    Mizakoto Problematica
    3 Jan 2011
    One word: Whoa
  17. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Looking Great Mac1as, fantastic attention to detail. Should make a great finished article :D
  18. mac1as
    mac1as Acid Veins
    14 Dec 2010
    I will try to put it all in to case, won't be easy:
    Some stuff inside:
    with cables:
    it wont be easy to organize it:
  19. KidMod-Southpaw
    28 Sep 2010
    Whoa, this gets better and better!
  20. mac1as
    mac1as Acid Veins
    14 Dec 2010
    I installed blocks for GPUs, MOBO & MEM:
