Scratch Build – In Progress [Scratch Build] 'Completed' Project Ethos & Cube - The Baby Grand
Discussion in 'Project Logs' started by SavellM, 19 Mar 2013.
  1. SavellM
    SavellM What's a Dremel?
    19 Mar 2013
    So I've been working on a little project (well you could call it little, but its pretty huge ;))
    Some background, I have a server rack in my spare room, with a Synology NAS rack mount, and a Gaming PC, with a monitor on top of it.
    Now this is OK, but sitting and using a rack as my desk is rubbish so I need a solution.
    Also the missus wants the rack out of there, so we can start re-using the spare room :)
    My friend is a carpenter, so I will be taking advantage of that in this build...
    First things first, designing a desk to fit both a server and a desktop.
    The server will be rebuilt and using FreeNAS, and then my gaming machine will be a nice new build.
    ______________________________________________
    Current Gaming PC Hardware:
    Configuration :
    CPU: Intel Core i7 6700k Skylake (Delidded)
    Motherboard: Asus ROG VIII Hero
    GPU: 2x NVIDIA Titan X
    SSD Boot: Samsung 256gb 850 Pro
    SSD Gaming Drive: Samsung 1tb 850 EVO
    RAM: Corsair 16GB DDR4 Dominator Platinum 3300
    PSU: Corsair AX1200
    Fan Controller: Lamptron CW611
    Monitor: Asus ROG Swift PG278Q
    Server:
    CPU: Intel Core i5 4670t Haswell
    Motherboard: Asus Sabertooth Z87
    HDD RAID: 5x WD Red 3tb
    RAM: Corsair 16GB DDR3 Arctic White Vengeance
    PSU: Seasonic Platinum Series 660w
    UPS: APC SmartUPS 1500
    Watercooling loop:
    CPU Block: EK-Supremacy EVO Clean Nickel
    Reservoir: 2x EK-RES X3 250 Reservoir
    GPU WB: 2x EK-FC Titan X - Nickel
    Pumps: EK D5 Vario Pump x2 with 2x EK-XTOP Plexi
    Radiators 360: XSPC AX360 Triple Radiator
    Radiators 480: XSPC AX480 Quad Radiator
    Tubes: Will be making Acrylic Tubing
    Fittings: Bitspower Deluxe White fittings
    I will be running 3M carbon on the inside and having everything on top of it, eg Mobo.
    I am also getting the mobo trays custom made out of perspex and then fitting using standoffs away from the desk.
    I will be running LED's under the tray so you get a white glow from under the mobo's.
    I will be using White and Blue Sleeving, as this will make a nice contrast to the black 3M Carbon.
    The lid of the desk will be made out of toughened glass with a laminate top to stop scratches.
    Can find an OCN build log here
    Some 98% completed pics:
    For more completed pics please:
    http://forums.bit-tech.net/showthread.php?t=257797&page=9
  2. SavellM
    19 Mar 2013
    So Desk Design:
    Some working shots, double checking the measurements and design in SketchUp
    Vaneering the cuts to make it look good
    Making the Curve
    Handles for the draws arrived
    Some 3M Carbon to put on the inside of the desk where the motherboards go
    Port hole for cables going into the desk
    Some Corsair Dominator Platinum 16gb ram I picked up early in a good deal
    Lamptron Fan controller for mounting into the front of the desk
    Some Enermax fans
    SD Card reader and extra USB for front of desk
    Something hidden inside a sexy velvet bag
    New PSU as it was found cheaply during sales
    So I have decided to detail some of the building work so far:
    Started out with 2 sheets of wood, and 1 solid oak posts:
    Meet Chris, my Carpenter friend...
    Cutting out the different sections we needed:
    A Pile of wood that will become something awesome:
    Got wood?
    Starting to iron on the sides so it looks pwetty:
    Veneering 101:
    Cutting out the curve:
    Biscuit joints:
    Joints:
    Some more:
    How they slot together, just missing the leg here:
    Plaining the legs:
    Legs all cut and ready:
    Making the curve, having to slice out so that it can bend on itself:
    Curve glued together:
    Curve held together for about 2 days:
    Torture:
    Finally free and checking the fit:
    Making the draws:
    Some more draws:
    Veneering the edges of draws:
    Curve veneered and ready to go:
    So pwetty:
    Cant get enough:
    Desk taken home to start being put together:
    First stand before we realised we needed to change it:
    Editing plans and cutting off the top:
    Sad to see it go, but its for the best:
    All cut up, and how it lies currently:
    Hopefully will start work next week again :)
  3. SavellM
    19 Mar 2013
    Motherboard standoffs arrived.
    These will hold the perspex motherboard tray off the bottom of the desk by 15mm.
    And some silicon rubber washers for most if not all my screws.
    Should help dampen some sound and provide some nice cushions :)
    And some beautiful sleeving:
    My first crimp ever!
    Came out so much better than I ever thought it would.
    Great tools make easy work :D
    And ofc famous drawings...
  4. SavellM
    19 Mar 2013
    First bits of my Watercooling Loop turned up.
    More to come of it.
    Some beautiful toys turned up.
    This is the start of my WC enthusiasm :)
    The Packages
    The Beat
    So shiny!
    Now I need to get on and finish the desk so I can get everything fitted.
  5. SavellM
    19 Mar 2013
    A bit of what we were working on yesterday:
    We have to start making the dropdown for desk 2.0.
    So pieces cut, and test fitting:
    Yup looking pretty good:
    All biscuit joints and holding its own :)
    Not looking too shabby:
    You can see the legs are cut down slightly.
    And also the draw section is up :)
  6. SavellM
    19 Mar 2013
    Something else awesome just turned up :)
    So bit of an update...
    Did some work yesterday afternoon.
    Decided to take apart the radiators and spray the shells white.
    So shells without the cores:
    End bits sanded down:
    Sanding away:
    Ends and shells all sanded down.
    Looks quite nice with the silver edges :D
    Did a coat of primer, but it was very windy so had some bubbles and some thick bits. So decided to sand it down again.
    Primer sprayed in garage = no wind!
    Looking better:
    Liking it in white!
    Started to do some more work on the desk:
    All standing:
    Back is on, hiding the insides away:
    Looks nice with the back on:
    Inside lip cut down, and from the inside with the back on:
    Cutting the draws down to fit the new design:
    Showing what it looks like from under the floor looking up the desk's skirt.
    Guess the back really does cover it nicely, you can just start to see the insides:
    Back for where the UPS will be standing upright:
    Back board joining onto desk:
    Draws being fitted, checking size and spacing:
    Back to do another coat of primer:
    After its dried for awhile:
    Looks really nice in white:
    Sexy!
    Some Moar:
    Quite like it with the grainy look, of the black still slightly coming through:
    Now, I just need to let the primer fully dry, and then I will spray it Matt White.
    Did a stain on a cut off piece of wood to check it matches my TV Unit at home. (I can report it is almost a perfect match)
  7. SavellM
    19 Mar 2013
    Oh man do I have an update for you guys.
    My mobo trays are finally cut and ready :)
    I will get them within the next few days, but these are the pics from the creator :)
    Also remember that Cube will be a server and a half height machine, and Ethos will be for my gaming so slightly larger to accommodate bigger that ATX size, eg the Rampage series of boards.
    And lastly its just a test fitting with a dummy board.
    *Warning, there are a lot of pics*
    Furball Zen likes this.
  8. YearZero
    YearZero What's a Dremel?
    16 Aug 2009
    *head-asplode*
    Nice, can't wait to see more!
  9. Cheapskate
    13 May 2007
    Some nice work. This should be awesome.:D
    Could you salvage the top cut to make a drawer that matches your curve?
    -Didn't know XSPC were doing their radiators like that. They could sell just the shrouds for sweet fan covers.
    -Interesting approach to mobo tray assembly too. The mounting risers are a nice find too. Don't be afraid to throw out a link or two.;)
  10. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    WOW! :jawdrop:. Just the table itself is a peace of art.
  11. Asouter
    Asouter --------
    18 Jan 2012
    That's some introduction, Nice looking desk, nope great looking desk!!
    I think the idea of turning the curved off cut into a draw is brilliant, it'll turn that desk from great to f##ing awesome
    subbed
  12. Furball Zen
    Furball Zen Shut up and Mod
    25 Jan 2012
    Ok ill be the Debby Downer and point out some issues i have.
    1. Its a drawer not a draw.
    2. Glass doesnt scratch, acrylic can.
    3. Primer is not needed unless youre covering black for a white top coat, nor is sanding the entire factory coating. Wind doesnt cause bubbles, improper painting does.
    4. Its a solid wood build, rubber washers wont isolate vibes from anything, the wood absorbs it. If your mobo vibrates id be worried for another reason.
    5. Its spelled veneer :)
    6. What kind of server are you running that 10 year old hardware couldnt handle it? Or your current 'gaming' board? Or is this another "look how much money i can spend on a build to try and impress you guys"?
    All that said, so you dont think im a total putz, welcome to BT and good luck on your desk. The wood and design are nice and i will stay to watch :)
  13. Asouter
    Asouter --------
    18 Jan 2012
    Thanks for correcting my spelling Debby ;)
  14. skybarge
    skybarge just chilling at work
    29 Feb 2008
    You can correct his lack of grammar and capitilisation too if you wanted :)
    Just a few points to knock back:
    - Glass can be scratched by anything harder, which includes most metals, perspex is an excellent
    choice for you build, since the tray looks like it'll be out of the way
    - The bubbles would be caused by incorrect temperature, or oil/debris on the surface. If you can, make a small shroud of of cardboard next time and do it in inside at room temp(if allowed)
    - You should always sand a gloss coat off before painting,so you did that right. It'll give the paint some grip to stick.
    - You should always use primer for bare metals, as you've done. It also allows you to fill in any slight imperfections. I think you've done a good job
    Loving your project, I agree with the step of waiting for the latest hardware! If you are going to build something amazing, put the latest and greatest/most efficient at the time :thumb:
  15. SavellM
    19 Mar 2013
    Hey Man,
    I appreciate any feedback I can get. So no hard feelings at all, and I'm looking to learn as much as I can from everywhere. I have never watercooled (spelled right? ;)) before so this is a first for me.
    2) This is why I got the top done in Glass, as I wanted it to be sturdy and last for awhile.
    3) I got bubbles as it was really windy so I had to spray close, which your right, is improper painting. Hence why I sanded that down again and did it properly in a closed area. Results were miles better!
    4) The rubber washers weren't for things like the mobo tray. They were for things like fans, HDD's and anything else with a moving part. I got a bunch so I can stick them anywhere I want. I would rather have them and not need them, than need them and not have them.
    5) Thanks :)
    6) The main and real reason I want a Haswell server builds is power efficiency. The 17w and lower CPU's make for a nice 24/7 server build. Also the native 6x Sata 3 (6gb/s) ports are a major plus in my books. My Gaming machine is using an old 1366 and currently a 560ti (which will be upgraded). So this build isn't about look at the latest greatest, but for real world improvements. To be fair, I have spent a lot on the desk itself, as this will last much longer than any hardware I put inside it ;)
    But any advice anyone can give, I'm all ears :)
    Asouter likes this.
  16. SavellM
    19 Mar 2013
    Some more of what Chris has been working on today:
    Mortise and tenon joint:
    And the Lid coming along nicely!
  17. SavellM
    19 Mar 2013
    So a bit of an update.
    Working on the Desk Sunday and finishing it off now before staining and taking it home.
    Getting ready to make the glass template
    Rough cut out
    Cuts in nice and close
    So nice
    Chamfer Edge
    Cut outs
    Chamfer'd Edge to join with the side
    Joined up
    All sorted ready to send off to get Glass cut
    Getting ready for staining...
    Filling any bits and then sanding it down.
    All joins filled
    Top re-veneered.
    Cutting down 4mm for the piano hinge
    Fits, Check
  18. SavellM
    19 Mar 2013
    Nice and snug
    Top fitted and working nicely!
  19. SavellM
    19 Mar 2013
    So update today.
    What we worked on yesterday.
    Finishing off the filling and sanding making sure its beautiful :)
    Staining started :)
    Getting Draws all stained up.
    This little bottle of stain goes so far!
    Looking good!
    Next we need to do a matt varnish to seal it in and add protection.
    Then were pretty much done on the build side.
  20. SavellM
    19 Mar 2013
    So bit of an update this afternoon.
    Got my desk home :)
    Doing some test fittings with the mobo tray fitting under.
    Its a tight squeeze!
    That is also without the standoffs raising it up :(
    Standoffs fitted... And testing it out
    My little helpers :)
    Gaming mobo in place.
    What it will look like with the 3m Carbon underneath!
    Backdrop highlights the perspex!
    Cant wait for the LED's underneath.
    That's all for tonight.
    Will slowly start to work on the insides now, exciting times...
