Case Mod - In Progress [COMPLETE] Project: ORANGE DRAGON - Fractal Design Core 1000 mod (2nd Feb, 2014)
Discussion in 'Project Logs' started by Shank8, 26 Jan 2014.
  1. Shank8
    Shank8 What's a Dremel?
    10 Jan 2014
    ORANGE DRAGON
    Hi all!
    This is my fist mod, and my first time posting. My project started a few months ago, with the intention of creating a watercooled, dragon themed, mini ITX build.
    I would like to get involved here as I've been a reader of Custom PC for a long time, and the builds on bit-tech have been a great source of inspiration for this build. As the project is well under way now, I thought I'd share my progress.
    Hope you enjoy this mod! All feedback is very much appreciated :) :dremel:
    SPECS:
    Case: Fractal Design Core 1000 (Orange Dragon mod)
    CPU: i5-3570K
    Motherboard: ASUS P8Z77-I Deluxe
    RAM: 8GB Crucial Ballistix Tactical Tracer
    GPU: GTX 670
    Storage: 256gb Samsung 840 SSD
    PSU: Seasonic X-series 750w
    Cooling: Watercooled - EK water blocks - Alphacool fittings
    Update! ORANGE DRAGON is now complete! Hope you enjoy the final Shots :)
    Thanks very much for viewing :)
  2. Shank8
    10 Jan 2014
    Drawing and cutting.
    I started of by drawing my window designs onto the panels.
    Fan holes for a 280mm rad at the bottom of the case.
    Had to use a spoon to prop up the loose bits while dremeling the top window :p
    :dremel:
    Used a dremel and hand file to get the fan holes to this stage. I then used sand paper to properly smooth out the edges.
    Top prevent the bottom of the case from sagging I made two little centre supports out of aluminium "L" channel. They're stuck on using a glue gun ...it looks pretty tacky, but hopefully nobody is going to be looking down there :p
  3. Shank8
    10 Jan 2014
    Rust
    Yes, that's a computer case in a bath of vinegar :)
    After sanding the case, I washed it down with water to get rid of the paint dust. But as I didn't dry it properly the case began to rust :wallbash:.
    I left the case in a bath of brown vinegar (23p per bottle from Aldi!) over night. The next day the rust came off nicely when scrubbed with wire wool.
    I quickly primed the case to prevent further rusting.
  4. Shank8
    10 Jan 2014
    Painting time
    Took three coats to get a deep orange.
  5. Shank8
    10 Jan 2014
    Assembly
    2x140mm fans for the bottom rad + smoked black acrylic for the top window.
    Dremeled out the stock power switch to make way for an orange LED one. :dremel:
  6. Shank8
    10 Jan 2014
    Watercooling loop
    Just in case...
    No leaks; happy days :D
    Mayhems orange dye works wonders!
  7. jrs77
    jrs77 Modder
    17 Feb 2006
    Totally like the orange colour of this one.
    I'm concerned about your temps there tho, seeing that both rads blow the heated air into the case only having a 92mm and the PSU as exhaust.
  8. Shank8
    10 Jan 2014
    Thanks very much! I had the same worry, but the CPU averages 27°C idle so hopefully it should be ok.
  9. Shank8
    10 Jan 2014
    All done! ...for now at least :)
  10. Deblow
    Deblow Minimodder
    12 Dec 2013
    That looks very nice indeed m8, well done! :)
  11. Nexxo
    23 Oct 2001
    Le fap, fap, fap...
  12. Shank8
    10 Jan 2014
    Finishing touches!
    Orange LEDs for the CPU block and res :D
