Scratch Build – In Progress Home Rack build, whole house audio & Spa TV
Discussion in 'Project Logs' started by dark_avenger, 6 Aug 2013.
  1. dark_avenger
    dark_avenger Minimodder
    9 Jul 2008
    Been living in my own house for a few years now I thought it was about time I "geeked" it up a bit and sorted out the mess that is my server/network cupboard.
    Sorry about picture quality my camera has died :(
    Cupboard was a slap together job to get it all hooked up and working and kinda just go left as it was working.
    All empty
    "Rackmounting" the amps for house audio.
    Just bought a 1U blanking panel and took to it with the angel grinder.
    Amps are "Class T" 20w per channel off ebay. Around $22 each. Not bad for the price and will do what I need for now.
    Back in a looking a little neater
    Patch panel arrived to tidy up CAT5 cables
    I'm waiting on the arrival of some rack rails which I intend to screw into the shelf and roof which will tidy it up even more.
    Also need to either buy or build a new case for the server as I have run out of room for more drives. (11 currently)
  2. dark_avenger
    9 Jul 2008
    Picked up some cheap ceiling speakers of ebay (~AUD$29 for the pair)
    Was pleasantly surprised at how they sound considering.
    First hole cut
    Both installed and wired above the spa bath.
    Next two installed in the kitchen/dining area
    Raspbery Pi running XBMC and Airplay to control it
    Thinking another two in the master bedroom and am going to mount a screen at the foot of the spa for movies, etc but haven't quite figure out the best way to mount it yet.
  3. dark_avenger
    9 Jul 2008
    Got the additional Raspberry Pi's setup last night bringing the total to 4 in the house.
    Airplay view from my iphone now.
    Audio-RaspPi will be connected to the amps that drive both the kitchen and deck speakers and the others will be kept separate to enable different music to be played in different rooms.
  4. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    I so need this in my life! Great little project dude :)
  5. dark_avenger
    9 Jul 2008
    It the sort of thing that you didn't know you missed but once it's there you think "why didn't I do this ages ago?"
    Still waiting on the rack rails so not much has been done on that front other than mounting the third and final amp.
    Deck -> Kitchen -> Bathroom
  6. dark_avenger
    9 Jul 2008
    Started on the bathroom TV over the weekend.
    Tried to just pull off the tiles but didn't have much luck so resorted to just cutting the hole out and then will just re plaster/tile around the screen when it's mounted with glass to cover the screen.
    Begins of the hole
    All cut out
    VGA and 12volt power run.
    Testing
    Friend is building up a custom bracket for the screen and then hopefully get the plastering done over the next week.
  7. dark_avenger
    9 Jul 2008
    Rack rails arrived today so finally got everything mounted.
    Didn't get some pics before I started mounting things but pretty much cut the rails with the angel grinder to length bent the bottom to sit on the shelf and then used self tappers to attach top and bottom.
    Patch panel and switch mounted
    Modem router and PSU mounted
    Everything mounted
    Mounted and powered up
  8. dark_avenger
    9 Jul 2008
    Spa telly testing using Iphone XBMC remote to control
  9. dark_avenger
    9 Jul 2008
    Bracket for the screen all mounted
    Screen mounted to bracket
    Hopefully getting the plaster done this week then just have to organize some tiles and glass to finish it off :)
  10. dark_avenger
    9 Jul 2008
    Been a little progress...
    Beginnings of the plastering
    With the screen test fitted
  11. Bladesingerz
    Bladesingerz Minimodder
    30 Nov 2011
    Nicely done :)
  12. landspeeder95
    landspeeder95 What's a Dremel?
    11 May 2010
  13. johnim40
    johnim40 Minimodder
    23 Apr 2009
    nice build so far are you going to get 1 of the waterproof cases for the phone
  14. dark_avenger
    9 Jul 2008
    Cheers :)
    All three amps are running off a 12v 12amp PSU thats mounted with the modem and router.
    I may look at doing the caps on them at some stage but so far they have been pretty good.
    I've got an old iphone 3GS that I'll probably use for the remote.
    Not too worried if it goes for a swim it's pretty stuffed.
    So far haven't managed to drop my phone in the bath (touch wood)
  15. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    It looks great and I would also like to have my house set up like that. One question Why such a big hole for the screen? They make stud finders for about $10. Great job none the less.
  16. dark_avenger
    9 Jul 2008
    Pretty much impossible to remove the tiles from the plaster without destroying them so it was easier to cut the whole tiled section out and then re tile the wall rather than stuffing around trying to cut tiles on the wall, etc.
  17. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    wow some really cool little ideas, might need to dig my PI out ;)
  18. dark_avenger
    9 Jul 2008
    They are a great little device. With the new "NOOBS" image on the Raspberry Pi site can have them up and running in 5 minutes now as well :thumb:
    Got 4 of them in the house now and one soon to be in the car. All running OpenELEC (XBMC)
  19. dark_avenger
    9 Jul 2008
    Replacement tiles have arrived and I've ordered the tinted glass to cover the screen.
    Hopefully in the next week it'll all be back together :)
  20. dark_avenger
    9 Jul 2008
    Little bit of progress. Plastering has been done and the tiles have arrived.
    Glass should be here any day and the wall can finally go back together haha.
