Go Back   bit-tech.net Forums > Recreation > Gaming > Game Server
Reply
Thread Tools
Old 2nd Nov 2011, 10:05   #1
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
The old CPC and Bit-tech Battlefield 3 server by MPUK
CustomPC magazine and Bit-tech.net have a MultiplayUK provided 32 player Battlefield 3 server.
Click HERE for Battlelog link to the server
Add the server to your favourites so you can find it in the future.
Voice chat information: Join us! it's not Battlefield without teamwork.
Game Mode and Maps:
  • Normal Conquest Large rounds (all maps except Op Metro, Gulf of Oman is in conquest small so no one side has distinct advantage)
  • Normal Rush rounds (Op Metro, Wake Islands, Damavand Peak, Seine Crossing and Sharqi Penisula)
  • Map voting is enabled, keep an eye out on the in-game chat. type /1, /2, /3, or /4 to vote
Other Details:
  • Do NOT attack enemy initial uncap spawn base. no exceptions, no jet strafing runs on it.
  • Normal mode server: 100% health, no friendly fire, 3D spotting and 3rd person vehicle camera
  • General rules on all CPC and Bit-tech servers
Admins: (on BF3 and Mumble)
In game commands to be used by these admins to look after the server and kick/ban cheaters or misbehaviour. Time is the typical time they will be on the server. There should be at least 2 admins around at peak times of 8 to 12.
  • Rogzy
  • Penderyn (Parge): 7 to 11 Mon, Wed, Thu, Sun
  • Fluidic: 8 to 12
  • dracaXL (Dub): 8 to 1am
  • DLDeadbolt: 6 to 1am
  • Lassar1982: 8 to 12
also, don't forget to become a fan of the CustomPC platoon.
wuyanxu is offline   Reply With Quote
Old 4th Nov 2011, 07:27   #2
Rogan
Not really a
Rogan's Avatar
Rogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming SaiyanRogan is a Super Spamming Saiyan
I added rush 2 round alternating. Need to decide which maps to remove for each mode.
Rogan is offline   Reply With Quote
Old 4th Nov 2011, 08:50   #3
wuyanxu
wuyanxu's Avatar
thanks Rogan. could fu, Nightbreed and i have access to it via Clanforge please? i'd like to see if i could setup a team scrambling plugin through the new ProCon.
i'd nominate Metro to be removed from Conquest. everything else seems fine at the moment. have not played any other game mode, so don't know which Rush map is terrible.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
Old 4th Nov 2011, 11:57   #4
Jake123456
Surprise!
Jake123456's Avatar
Jake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming SaiyanJake123456 is a Super Spamming Saiyan
Could you set it up so when it got filled up the Rush maps will be played? Like the BC2 Server?
__________________
PSN - TickleMyMoose
Originally Posted by Ending Credits View Post
If I ejaculated a 1.5TB HDD I'd probably do it again from the excitement.
Jake123456 is offline   Reply With Quote
Old 4th Nov 2011, 18:01   #5
Fluidic
Multimodder
Fluidic's Avatar
Fluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for presidentFluidic should be considered for president
would like to see if possible to add the extra cost for a 64player? either just myself or a collective donation.
Fluidic is offline   Reply With Quote
Old 4th Nov 2011, 19:34   #6
Rogan
Not really a
Rogan's Avatar
Could you pm me your clanforge emails. I've forgotten them.
Old 4th Nov 2011, 20:03   #7
fu manchu
I'll have the special.
fu manchu's Avatar
fu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyan
Its OK Rogan, I have added them now.
fu manchu is offline   Reply With Quote
Old 4th Nov 2011, 20:45   #8
Rogan
Not really a
Rogan's Avatar
Cheers Fu.
Not until the bugs are worked out with the 64 slot servers, and the current server is impossible to get onto. Then I'll take another look at the angles and see what can be done.
Old 4th Nov 2011, 21:01   #9
wuyanxu
wuyanxu's Avatar
thanks Rogan.
ok, new mumble server configured. auto-join into muted AFK, then select the channel. hopefully should encourage people to make use the channels.
First post updated with new mumble details
ProCon setup, zero plugin it seems. will check up on it and play around with it tomorrow when the server is empty.
__________________
Old 4th Nov 2011, 21:24   #10
Rogan
Not really a
Rogan's Avatar
Guys there's a little tickmark that says "Restart servers that are 'already' set to this profile".
You need to make sure that's unchecked when making changes. If you need to restart a populated server it's good form to warn the players first.
edit: And queuing seems to be disabled now.
Old 4th Nov 2011, 23:52   #11
GravitySmacked
Mostly Harmless
GravitySmacked's Avatar
GravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming SaiyanGravitySmacked is a Super Spamming Saiyan
New server added; looking forward to talking (probably inebriated) to you all again tomorrow.
GravitySmacked is offline   Reply With Quote
Old 5th Nov 2011, 12:15   #12
wuyanxu
wuyanxu's Avatar
sorry Rogan, i was setting the auto-restart period, didn't know it will restart the whole server.
how to enable queuing?
__________________
Old 5th Nov 2011, 17:13   #13
Rogan
Not really a
Rogan's Avatar
I think it may be related to procon.
Old 8th Nov 2011, 21:46   #14
Telltale Boy
Designated CPC Jetwhore
Telltale Boy's Avatar
Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.Telltale Boy is definitely a rep cheat.
The sooner they get queuing back and working the better, continuously hitting refresh on the CPC server for 5 minutes is not fun.
__________________
Telltale Boy is offline   Reply With Quote
Old 8th Nov 2011, 21:49   #15
FuzzyOne
FuzzyOne's Avatar
FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!FuzzyOne - it's over 9000!!!!!!!!1!1!1!!!
Lots of grease monkey scripts out there for autojoin, I use http://www.coderah.com/?page_id=389
__________________
FuzzyOne is offline   Reply With Quote
Old 8th Nov 2011, 23:02   #16
Telltale Boy
Brilliant! This should do just the job. +rep
__________________
Old 9th Nov 2011, 01:32   #17
nchhabs
www.twitch.tv/dracaXL
nchhabs's Avatar
nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.nchhabs is a hoopy frood who really knows where their towel is.
Just a note to say that "Chrysim" [score was 38-1] should be banned for blatant hacking last night on the server - wallhacks/aimbot + abusing other players. (this is dracaXL/Dub - was on the server playing with F1BR3 and Icy1982. He came on around 1AM.
nchhabs is offline   Reply With Quote
Old 9th Nov 2011, 02:29   #18
Rogan
Not really a
Rogan's Avatar
Get yourself and two regular late night players and I'll ask wyx to sort your admin. Just use it to ban cheats and kick asshats; there'll be no problems.
Old 9th Nov 2011, 05:20   #19
PhoenixTank
From The Ashes
PhoenixTank's Avatar
PhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the DremelPhoenixTank has yet to learn the way of the Dremel
I was around for that as well. I can't say I saw any blatant hacking (though the K/D was ridiculous).
Wondered if he was being fed info by a buddy (Agar4life), but there were a few people complaining about him, so I defer to them.
Attached the battlelog, if it helps.
http://battlelog.battlefield.com/bf3...8/1/256029821/
Edit:
And the round immediately after that:
__________________
i7 980x stock | Asus Rampage 3 Extreme | Corsair H50 W/ 2x Sharkoon Silent Eagles SE
48GB Corsair Vengeance (3x CMY16GX3M2A1866C9R) | 2x Samsung F3 1TB | 2x Crucial C300 256GB (Boot & Steam)
Asus Mini GTX 960 | HP ZR24w | 32' Samsung B550 | Formac Gallery Xtreme 20.1" MVA
Scythe Kaze Server (fan controller) | Lian Li PC-A77FB | W-75BT Side Panel Window
PhoenixTank is offline   Reply With Quote
Old 9th Nov 2011, 10:41   #20
wuyanxu
wuyanxu's Avatar
cheers Phoenix and Dub. will look into him when i get home.
admins need to be sorted, i'd never have thought there are cheats out already!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
