Old 14th Dec 2011, 16:15   #1
fu manchu
I'll have the special.
fu manchu's Avatar
fu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyanfu manchu is a Super Spamming Saiyan
CS:S server problem
We are going to have to run the server totally clean for a couple of days to try and get to the bottom of these random mapcycle restarts. There will be no plugins or scripts running at all, although admin can use rcon to keep things in order.
Can you post here times and scenarios of any mapcycle or server restarts.
Thanks
fu manchu is offline   Reply With Quote
Old 16th Dec 2011, 19:45   #2
DaveODeth
Multimodder
DaveODeth has yet to learn the way of the Dremel
Would have posted this earlier but the interwebs fell on it's arse. Getting regular lag spikes from the server, small but for around 0.5 seconds. First I thought it was me but we've all been suffering.
DaveODeth is offline   Reply With Quote
Old 16th Dec 2011, 20:05   #3
fu manchu
fu manchu's Avatar
Is this in general or specifically since I removed all plugins and scripts on Wednesday?
Old 17th Dec 2011, 10:09   #4
church^
Minimodder
church^ has yet to learn the way of the Dremel
well when i was on there with everyone i was getting lag then every else said they we getting it, there seemed to be a drop in the tick rate output from the server , is the cpu spiking?
church^ is offline   Reply With Quote
Old 17th Dec 2011, 13:39   #5
fu manchu
fu manchu's Avatar
If you are talking about Wednesday evening, then that was probably caused when Steam threw a major strop, it went on for hours, or was that Thursday? One or the other. Server CPU loads looks normal.
The thing we are trying to see, is if the server does the weird mapcycle restart thing that it has been doing lately, with all plugins and scripts off. Typical that steam decides to mess around and dish out these stupid present updates when we are trying to fault find.
Old 17th Dec 2011, 19:09   #6
Major D
Minimodder
Major D has yet to learn the way of the Dremel
The night everyone had lag was when steam was playing up. Certainly was the case for me anyway.
Major D is offline   Reply With Quote
Old 23rd Dec 2011, 22:13   #7
DaveODeth
Multimodder
After the removal, it has stopped now or at least I don't notice it as much.
Old 23rd Dec 2011, 22:53   #8
fu manchu
fu manchu's Avatar
Yes that seems to be the case. I will start adding the plugins one by one over next few days and see what it does.
Old 5th Jan 2012, 12:11   #9
DaveODeth
Multimodder
Just a quick question, is anyone getting fairly regular spikes on the server. Roughly once every couple of mins or so. Nothing major but it can get a bit distracting.
Old 11th Jan 2012, 20:51   #10
DaveODeth
Multimodder
Something very odd tonight
1 2 ms <1 ms <1 ms 192.168.0.1
2 22 ms 21 ms 22 ms lo0-central2.thn-ag03.plus.net [195.166.128.48]
3 23 ms 21 ms 21 ms unknown.plus.net [84.92.3.216]
4 21 ms 21 ms 21 ms po6.ptn-gw02.plus.net [212.159.1.137]
5 23 ms 23 ms 24 ms 195.66.226.224
6 191 ms 184 ms 182 ms blade35-101-24.multiplay.co.uk [85.236.101.24]
few of us on the server suffering 200 pings for no discernible reason.
Old 11th Jan 2012, 20:58   #11
DaveODeth
Multimodder
1 1 ms <1 ms <1 ms 192.168.0.1
2 21 ms 22 ms 21 ms lo0-central2.thn-ag03.plus.net [195.166.128.48]
3 23 ms 23 ms 23 ms unknown.plus.net [84.92.3.216]
4 22 ms 22 ms 22 ms po6.ptn-gw02.plus.net [212.159.1.137]
5 63 ms 208 ms 207 ms 195.66.226.224
6 172 ms 168 ms 172 ms blade35-101-24.multiplay.co.uk [85.236.101.24]
2nd one
and a third for good measure.
2 23 ms 22 ms 23 ms lo0-central2.thn-ag03.plus.net [195.166.128.48]
3 22 ms 21 ms 21 ms unknown.plus.net [84.92.3.216]
4 21 ms 21 ms 22 ms po6.ptn-gw02.plus.net [212.159.1.137]
5 24 ms 25 ms 23 ms 195.66.226.224
6 191 ms 182 ms 175 ms blade35-101-24.multiplay.co.uk [85.236.101.24]
Old 11th Jan 2012, 21:18   #12
Major D
Minimodder
Strange one tonight, about half a dozen players with same problem as Dave. Dieharder, matt, indi..all had a ping around 180ish which could not be resolved. Baffled!
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
