Go Back   bit-tech.net Forums > Technology > Hardware
Reply
Thread Tools
Old 19th Apr 2015, 13:32   #141
edzieba
Virtual Realist
edzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyanedzieba is a Super Spamming Saiyan
Originally Posted by Parge View Post
a custom solution
A SimLight? I'll probably finish throwing mine together today if the weather clears up.
edzieba is online now   Reply With Quote
Old 19th Apr 2015, 15:38   #142
Impatience
Ultramodder
Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.Impatience is definitely a rep cheat.
Had some use with the Cyborg Pro, mouse and Nostromo combo.. Love using the Nostromo and mouse.. Feels just, right! With how it fits in my hand etc.
With the Cyborg though, it wont want to work on SC.. Has a constant tilt, so the ship just lists to one side. Also, it only moves in one direction when you twist and leaning the stick. The throttle doesn't work on SC either.. Not sure if that's just the game settings though? As i've installed the latest drivers for it (although the bundled software is XP and refuses to run on Win7, even in compatibility mode!) Any experience hints for setting it up?
Impatience is offline   Reply With Quote
Old 27th Apr 2015, 16:04   #143
Impatience
Ultramodder
Update on my previous post.. It turns out it was recognising my Nostromo as Joystick/HOTAS1 and the Joystick as J/H2, so wasn't recognising the inputs from the 'stick! (Auto-set to J/H1)
Old 6th May 2015, 20:41   #144
esxboi37
What's a Dremel?
esxboi37's Avatar
esxboi37 has yet to learn the way of the Dremel
Can anyone recommend a good joystick for IL2 sturmovik flight sim?
esxboi37 is offline   Reply With Quote
Old 11th May 2015, 15:59   #145
mstrchf
Minimodder
mstrchf's Avatar
mstrchf has yet to learn the way of the Dremel
I currently use a Thrustmaster T.16000 M for sturmovik. Really accurate but buttons are a bit clunky.
Any of you guys tried the Defender Cobra M5?
https://www.youtube.com/watch?v=Qsrt_Sc4Seo
__________________
MSI Z77A-GD55 - Intel i5 2500k @ 4.5ghz + Noctua NH-D15 Cooler - 8gb DDR3 Corsair Vengeance C9 1600Mhz -
MSI R7950 TF 3GD5/OC BE + Accelero Xtreme III Cooler - Samsung 120GB 850 EVO SSD - WD Blue 1TB HDD -
Antec HPG 520W 80+ Bronze PSU - Dell 23" 1080p IPS U2312HM - Fractal R5 Case
mstrchf is offline   Reply With Quote
Old 20th Sep 2015, 22:51   #146
Parge
the worst
Moderator
Parge's Avatar
Parge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming SaiyanParge is a Super Spamming Saiyan
Anyone seen these? I'm tempted to order one for the warthog, what with the pound so strong against the euro right now.
__________________
Ediface
Silverstone FT03 Mini - i7 4790S - Noctua NH-L9i - Gigabyte GTX 1070 'ITX Edition' - Maximus Impact VII - 16GB DDR3 - 1TB NVME - SF600 - AOC Agon AG271QG - Xonar U7 - Bassshaker - RAT3 - Majestouch Minila - Q90s - Orbweaver - Warthog
Parge is offline   Reply With Quote
Old 21st Sep 2015, 04:59   #147
Pete J
RIP Teelzebub
Pete J's Avatar
Pete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming SaiyanPete J is a Super Spamming Saiyan
IMHO, I wouldn't go for those, Parge. They look like they'll mark your desk and won't be secure enough.
__________________
Latest system review here / I also have a laptop: Gigabyte P35X v6
HTC Vive review coming soon!
Pete J is offline   Reply With Quote
Old 21st Sep 2015, 18:21   #148
Cei
pew pew pew
Cei's Avatar
Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.Cei is definitely a rep cheat.
Easy to fix that, just apply some padding. I looked at the old Joylocks that were very similar but they went off-sale. So basically, go for it.
__________________
Join the BitSec organisation in Star Citizen! | Fleet Roster
i7 3770K | Asus RoG Maximus V Gene | 16GB 1866Mhz Vengeance | Crucial M4 256 & Samsung EVO 500 | Corsair H105 | Corsair AX860 | GTX 1080 FE | Air 240
i5 4670K | Asus RoG Maximus VI Impact | 8GB 1866Mhz Vengeance LP | Samsung 840 EVO 128GB | Noctua NH-U9B SE2 | GTX 770 SC 2GB | EVGA Hadron Air
Cei is offline   Reply With Quote
Old 21st Sep 2015, 18:48   #149
rainbowbridge
Banned
rainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyanrainbowbridge is a Super Spamming Saiyan
I really like the look of those mounts, some one has put some care into the design, build and propose, looking at that claim handle looks impressive.
I vote get also.
rainbowbridge is offline   Reply With Quote
Old 22nd Sep 2015, 12:35   #150
asura
jack of all trades
asura's Avatar
asura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyanasura is a Super Spamming Saiyan
This is bit-tech!* Build your own? This is the profile used which at about £20/m + 50p per cut done for you is cheep as chips, from the same place you can get all the connectors and end pieces all that's left to figure out is the clamp.
*not patric?
asura is offline   Reply With Quote
Old 22nd Sep 2015, 13:01   #151
Parge
the worst
Moderator
Parge's Avatar
I’ve chatted to a few people that have bought them and apparently they are absolutely solid. They do have a pad below the top clamp – so maybe those marks are from prototypes that didn’t or something?
Yes, I looked at them – they looked good, but like you say, went off sale and didn’t have any real adjustability. I’m not lucky enough to have space for an obutto etc, and the wheelstand pro didn’t suit me, so I’ve been on the lookout for a better solution.
I vote get also.
The guys making them is German, so I expect good design and engineering. One thing I would like to see is a rounded, semi circle edge for the warthog plate. Don’t want to accidently impale myself on the corner while sliding it my desk.
Sadly living in London makes building anything pretty hard, I don’t have tools, a garage or any real space around my apartment for work like this.
__________________
Ediface
Old 22nd Sep 2015, 14:39   #152
suenstar
Collector of Things
suenstar's Avatar
suenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyansuenstar is a Super Spamming Saiyan
Sounds like an interesting idea, not sure why creating a set of simple clamp-on bases didn't occur to me when I started building my custom flight rig.
I might have to play around with some some similar desk mounts when the parts for my new desk arrive on Friday.
Small clamps are relatively cheap so it shouldn't cost much to play around with some different layouts... though I do still want to continue attempting to build my flight stand.
The guys making them is German, so I expect good design and engineering. One thing I would like to see is a rounded, semi circle edge for the warthog plate. Donít want to accidently impale myself on the corner while sliding it my desk.
As an alternative to pre-cut rounded edges, you could use adhesive backed rubber strips along the edges or little foam pads on the corners.
__________________
PSN: suneai | Steam: Critical Clicks | Origin: suenstar | Elite Dangerous & Star Citizen: surren starr
suenstar is offline   Reply With Quote
Old 22nd Sep 2015, 16:29   #153
asura
jack of all trades
asura's Avatar
You have as many hacker spaces in greater London as there are in the whole of Scotland - "new" one in Aberdeen since I checked last, may have to swing by one of these years...
And the point of these profiles is that there isn't much work needed, they go together with T-nuts and bolts. Give them the lengths you need and they'll cut the profiles for you - similar companies offers similar services for sheet. The most complex part of the whole thing would be the drilling of two holes in each plate and rounding the edges to reduce the skraggyness.
What I'm getting at, is that you could build something as good yourself for about £15-20.
Old 20th Nov 2015, 05:30   #154
Pete J
RIP Teelzebub
Pete J's Avatar
Thought I'd resurrect this thread due to my experiences with finding the ultimate stick to use for Star Citizen!
1) X55: At first I was impressed by this as it was the first HOTAS I've owned. However, I found the joystick way too big and light after a little while. The throttle is excellent, but HOTAS and Star Citizen do not go well together at the time of writing. Still, bought for £143 new, sold for £167 on eBay. Profit!
2) Cyborg Fly 5: After reverting to my Sidewinder Force feedback II, it unfortunately started to start missing button presses. I looked at two options, one of which was the Fly 5. Well, don't go anywhere near it! Due to its design, it's a bit loose and moves around.
3) Extreme 3D Pro: A good starter stick with just the right amount of buttons and button placement. I used this for a little while but found that the sensor accuracy was not too good. Absolutely fine for single player but against a hardened Star Citizen player, the lack of resolution for the dead zone was telling.
4) Warthog: I manned up and went for the Warthog. This is THE best stick I have used. Fantastic accuracy, a good size for my hand and a good amount of well placed buttons and hat switches. The movement is smooth as and has excellent accuracy. Build quality is amazing and the weight of the stick means it doesn't slide around. Although expensive, anyone who buys this will not be disappointed.
5) T16000: I bought this as a secondary joystick to try dual joystick flying, which I eventually decided I didn't like and went back to my G13/Warthog combo. The stick has good points and bad points. The good is that it is exceptionally accurate (possibly more so than the Warthog), has a smooth action and is of decent build quality; it can also be physically reconfigured for left hand use. The bad is that it's relatively light and I found that when twisting it, I'd end up moving the base slightly; also, the head is too wide and makes moving your thumb to get at buttons awkward. I'm going to keep it as a backup/travelling joystick.
__________________
Old 28th Dec 2015, 22:55   #155
Parge
the worst
Moderator
Parge's Avatar
Finally got round to ordering a table mount for the Warthog. It wasn't cheap (£80) but I've found nothing else that comes close. The new version comes with a rounded mount to fit the base of the stick. I'll do a mini review when it arrives in case anyone else is interested.
__________________
Ediface
Old 12th Mar 2016, 12:36   #156
Parge
the worst
Moderator
Parge's Avatar
By the way - been using this for a while now - I can safely say they are absolutely EXCELLENT.
Takes about 5 minutes to assemble, two seconds to lock into place and remove so you don't look like an ubernerd if you bring a girl back (though the huge Mechwarrior Online print I have might give the game away too). Build quality is great - good old German engineering.
One thing that didn't quite work for me is that I personally found the stock version too long horizontally - the plate where the Warthog is mounted pushed me away from my desk which I needed to reach because my setup is Warthog + Orbweaver (and mouse for the FPS parts of the game). So, after some careful planning and measuring I put in an order for a shorter version - just 158mm long. My stick is mounted around halfway up the vertical mount, but diagonallly so that my wrist isn't at a funny angle in game (see bottom pics). This, combined with the raised base of the Warthog and the height at which I use it made me realise I didn't need that much clearance at all, so I did some tests and from what I could tell I could get away with cutting 80mm off the stock mount and still have clearance.
Upon first unwrapping the new custom mount my initial reaction was "holy crap that is short - did I measure it correctly?"
Comparison shot, stock mount on top
In order to fit the stick to the baseplate, I also required this part to be shorter - the stock one would have blocked the Warthog mounting holes.
As you can see, this one doesn't.
Now fitted - though this shot was taken before I adjusted the mounting height.
And setup! You can see in the below what I mean when I say my stick is mounted diagonally.
This setup is perfect now. It allows me to get super close to my desk, with my stick securely in between my legs. For those wondering, using this setup, moving the stick as far forward as it goes, I still have about 10mm of clearance between my hand and the vertical part of the mount.
__________________
Ediface
Old 12th Mar 2016, 16:40   #157
kosch
Trango in the Mango
kosch's Avatar
kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.kosch is definitely a rep cheat.
Sweet where did you order that from?
__________________
Living the dream since 2004 -
Become a Star Citizen & sign up with Bit-Sec the official Bit-Tech organisation Use my referral code for an extra 5,000 credits!
kosch is offline   Reply With Quote
Old 12th Mar 2016, 16:52   #158
Parge
the worst
Moderator
Parge's Avatar
Linky.
__________________
Ediface
Old 12th Mar 2016, 17:09   #159
IanW
Grumpy Old Git
IanW's Avatar
IanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming SaiyanIanW is a Super Spamming Saiyan
Link bookmarked for future use.
__________________
i7 4770K@3.9GHz / Corsair H100i / Asus Maximus VI Gene / 16GB Corsair Vengeance 2133 /
Asus Strix GTX1080 Advanced / 500GB Samsung 840 Evo / 1TB Sandisk SSD / BeQuiet! 1kW /
Thermaltake Core V21 / Dell U2713HM / Corsair K70 RGB / Logitech Performance MX / Win10 / Kubuntu 17.04
IanW is offline   Reply With Quote
Old 12th Mar 2016, 19:54   #160
Cei
pew pew pew
Cei's Avatar
That's beautiful. Really good space-saving method as well.
__________________
Reply
Tags
say yes to skimmed milk
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
