Go Back   bit-tech.net Forums > Partner Forums > MSI UK
Reply
Thread Tools
Old 5th Aug 2015, 13:41   #1
MSIRawZ
MSI UK Rep
MSIRawZ's Avatar
MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.
MSI Z170 Performance GAMING Motherboards
Introducing our Performance series of Z170 motherboards. Engineered to provide both a stunning gaming and visual experience, the MSI Z170 Performance GAMING series give you plenty of reasons to show off. The MSI Z170A GAMING PRO is an extremely customizable platform, allowing you to display your unique style with Mystic Light while placing a vast array of powerful gaming features at your disposal. Brandishing the sleek black & white color scheme, the MSI Z170A KRAIT GAMING has a striking design that delivers the coolest gaming experience.
Choose Your Destiny!..
Z170A GAMING PRO
Z170A KRAIT GAMING
Defining features of the MSI Z170 Performance GAMING series motherboards:
Customize and set up your own color scheme with Mystic Light. Make your PC look & feel brand new!
Load your games in the blink of an eye with blazing fast Turbo M.2 data transfer speeds up to 32Gb/s.
Enjoy crystal-clear immersive in game sounds from the premium quality components of Audio Boost 3.
Adjust your DPI and accuracy on the fly with easy to use Mouse Master software.
Assign your own hotkeys with Gaming Hotkey to boot your PC or launch games with a single keystroke.
Ready to support the most heavyweight graphics card setups with reinforced Steel Armor PCI-e connectors.
Superfast online gaming with MSI GAMING LAN powered Intel.
More Performance series motherboards due soon. Keep an eye out!
MSIRawZ is offline   Reply With Quote
Old 2nd Sep 2015, 14:54   #2
MSIRawZ
MSI UK Rep
MSIRawZ's Avatar
Another one to add to this series:
Z170I GAMING PRO AC
And yes it does support M.2 on the rear:
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
