Go Back   bit-tech.net Forums > Partner Forums > MSI UK
Reply
Thread Tools
Old 17th Aug 2015, 10:52   #1
MSINotebookUK
Multimodder
MSINotebookUK has yet to learn the way of the Dremel
Broadwell vs Haswell Part 3
Broadwell vs. Haswell part 3: wPrime
Part 3 in our article series of highlighting the advances on the CPU market brings us to yet another benchmark wPrime. Basically, wPrime calculates prime numbers for the fun of it, much like SuperPI calculates decimals of Pi. It is a synthetic benchmark, meaning it necessarily has no bearing on real-life performance.
The benchmark is multi-threaded and will use all available CPU threads once you let the benchmark know. In our case, we set the thread count to 8, which both our Haswell and Broadwell CPU has, and run a 1024M calculation.
Two things become apparent one is that the newer Broadwell is a lot faster. Weve seen this before in Cinebench and WinRAR, but not by these margins. Another thing is that the older Haswell-based i7-4720HQ is a bit more inconsistent over three runs, although not by much at all.
In any case the victory is a walkover. The i7-5700HQ cuts almost 40 seconds from the calculation time of its predecessor. Once more though, it should be stressed that the wPrime benchmark is completely synthetic, unlike our previous benchmarks. Its still three out of three for i7-5700HQ over the i7-4720HQ.
MSINotebookUK is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
