Go Back   bit-tech.net Forums > Partner Forums > MSI UK
Reply
Thread Tools
Old 16th Dec 2016, 09:06   #1
MSIRawZ
MSI UK Rep
MSIRawZ's Avatar
MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.MSIRawZ is definitely a rep cheat.
MSI Next Gen Mobo Sneak Peek - DDR4 Steel Armour & Front Panel Type-C
The next gen MSI GAMING motherboards come with improved DDR4 Steel Armour. Forged from a single piece, with more soldering points for better grounding, to deliver the best EMI protection.
Ready for next generation PC cases such as the upcoming PHANTEKS Enthoo Elite, the MSI GAMING motherboards feature a new industry standard USB 3.1 Gen2 Front Panel Header for Type-C, with speeds up to 10Gb/s.
MSIRawZ is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
