Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 10th Feb 2017, 15:25   #21
Drachnem
Supermodder
Drachnem's Avatar
Drachnem has yet to learn the way of the Dremel
So as suggested been running with only the below hooked up and have not had any issues.
  • M.2 Installed to board
    M.2 Installed via PCIe
    1 1070
    all ram
This means the nvidia audio driver didn't cause it, nor is the ram, or the single gpu, or the m.2, or cpu.
going to keep adding a thing at a time.
__________________
[TheTower900][i7 5820K][MSI X99 SLI Plus][Cosair Vengeance 32gb][Evga 1070sc 2-way SLI][Samsung 950 Pro M.2 (512GB & 1TB)][3x 3TB HDD][Evga Supernova 1200 PSU][Nzxt Hue +][4x Samsung 950 Pro SSD 1TB][Oculus Rift + Touch][Acer 27 2k Predator & 34 Curved 4k Dell]
Drachnem is offline   Reply With Quote
Old 10th Feb 2017, 15:36   #22
Yadda
Vegan Sandwich
Yadda's Avatar
Yadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming SaiyanYadda is a Super Spamming Saiyan
    1 1070
    all ram
That's the way, good to see you're getting somewhere.
__________________
Lost a Duff, gained a Charlie.
i5 4690k @ 4.6GHz / ASRock Z97m OC Formula mATX / 2x8GB Crucial Tactical DDR3 @ 2200MHz C10 / EVGA GTX 780 @ 1200/6400MHz / BX100 250GB SSD / Seagate 2TB SSHD / Nepton 240m AIO / EVGA 600B PSU / Corsair Carbide Air 240 / Win10 Home / 1080p monitor / Logitech MOMO wheel
Yadda is offline   Reply With Quote
Old 18th Feb 2017, 19:08   #23
Drachnem
Supermodder
Drachnem's Avatar
Update:
I have narrowed it down to 3 possibilities
  1. PSU power consumption too much
    Video Drivers (Sli issue?) or maybe need high bandwidth bridge
    2nd Video Card
I installed the other card and will test it out solo and see where that goes...
__________________
Old 20th Feb 2017, 20:15   #24
Drachnem
Supermodder
Drachnem's Avatar
Issue is not resolved
Bought a new power supply (1200 platinum) and still running into the same error...
I'm starting to think SLI is garbage.
I'm frustrated and out of ideas.
Anyone?
__________________
Old 20th Feb 2017, 21:26   #25
LennyRhys
Fan Fan
LennyRhys's Avatar
LennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming SaiyanLennyRhys is a Super Spamming Saiyan
I think you're on the money - the problem only presents after you connect the second video card.
Looks like it might be time to abandon SLI if you are certain both cards are in perfect working order?
__________________
i7 5820K | MSI X99A Gaming 7 | 32GB Ballistix Sport | EVGA GTX980Ti SC | Corsair RM550 | Dell U3014
LennyRhys is offline   Reply With Quote
Old 21st Feb 2017, 02:19   #26
Drachnem
Supermodder
Drachnem's Avatar
After reading on some random forums some folks said uninstalling motherboard software may help, so I did that, guess i'll see what happens.
__________________
Old 22nd Feb 2017, 01:30   #27
Drachnem
Supermodder
Drachnem's Avatar
That didn't work either. I'm at a loss here. Any other ideas?
__________________
Old 24th Feb 2017, 04:20   #28
Drachnem
Supermodder
Drachnem's Avatar
SLI bridge did not fix the issue either. Anyone have any other ideas?
__________________
Old 24th Feb 2017, 04:55   #29
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Probably a silly question but do you have sli enabled in nvidia control panel?
GeorgeK is offline   Reply With Quote
Old 24th Feb 2017, 05:03   #30
Drachnem
Supermodder
Drachnem's Avatar
Yes.
__________________
Old 24th Feb 2017, 09:03   #31
LennyRhys
Fan Fan
LennyRhys's Avatar
I keep getting the feeling that you're fighting a losing battle dude. It's possible that the motherboard is at fault and can't run SLI, but to diagnose that you'd have to get another board which is a bit extreme.
__________________
Old 8th Mar 2017, 03:29   #32
Drachnem
Supermodder
Drachnem's Avatar
100% faulty motherboard.
Got a new one (same one) and it worked like a charm.
Thanks everyone for the help!
__________________
Old 8th Mar 2017, 09:49   #33
LennyRhys
Fan Fan
LennyRhys's Avatar
Awesome news - what a pain in the butt it was to get it sorted, but you came out on top.
__________________
Old 8th Mar 2017, 17:01   #34
killingit
Minimodder
killingit has yet to learn the way of the Dremel
I was about to tell you to reinstall the Nvidia Driver. But, it is nice to know that you've resolved the issue mate.
killingit is offline   Reply With Quote
Old 1st Apr 2017, 03:09   #35
Drachnem
Supermodder
Drachnem's Avatar
Yes, thanks again for all the help.
Now on to the next thing...getting watercooling help
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
