Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 16th May 2017, 19:35   #21
iWalkingCorpse
What's a Dremel?
iWalkingCorpse has yet to learn the way of the Dremel
Only a small update for this week, jigsaw and a couple of things I needed to cut the thicker acrylic I have have arrived. Was going to mock up the gpu loop with flex, but decided to strip the paint off of the block so that's also on hold. So far I've been finishing one job, and creating 4 more. I think I'm getting close to the tipping point where I won't be adding as many jobs to the list, or they'll be end-time finishing jobs instead of hurdles.
Have almost finished all the PSU cabling now, just the 24-pin to do now. The PCIE ones turned out beautifully and am really happy with the coherent design.
until next time, Mod On!
iWalkingCorpse is offline   Reply With Quote
Old 17th May 2017, 17:10   #22
mnpctech
bit-tech sponsor
mnpctech's Avatar
mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.mnpctech is definitely a rep cheat.
sweet color scheme
__________________
My GPU support brackets We Ship International Orders!
mnpctech is offline   Reply With Quote
Old 23rd May 2017, 23:33   #23
iWalkingCorpse
What's a Dremel?
Well that took a lot longer than I’d anticipated. Still have a couple of strands to put into the main 24-pin cable but happy with the results so far. Still have to sleeve various other things, but I’m going to let my fingers heal up before tackling those. Seeing these finished in a pile has given me renewed vigor to tackle the rest of the build.
Alphacool NexXxos Fury X Waterblock
Next stage is some mods to the waterblock for the Fury X that I’m using in this build, and to put the gpu loop together with flex tubing to test my desired config.
Until next week, Mod On!
Old Yesterday, 13:27   #24
mnpctech
bit-tech sponsor
mnpctech's Avatar
We're you able to get your replacement EVOLV case?
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
