Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 25th Mar 2017, 20:04   #1
Wiltsh094
What's a Dremel?
Wiltsh094's Avatar
Wiltsh094 has yet to learn the way of the Dremel
I hope problem will be solved
When I was working in MS Word 2007 I got an error message: Word was unable to read this document. It may be corrupt. It happened after second opening .docx file. I search word recovery solution or method. Any tips…
Wiltsh094 is offline   Reply With Quote
Old 26th Mar 2017, 18:05   #2
FatalSyntaxError
Minimodder
FatalSyntaxError's Avatar
FatalSyntaxError has yet to learn the way of the Dremel
Hey,
In word 2007, you can try to open the file using the open and repair feature.
  1. Open word then click the Microsoft button.
  2. Click the open button to open a file.
  3. Select the file you want to open.
  4. Click the little drop down arrow on the open button and select open and repair.
Hope this helps
FatalSyntaxError is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
