Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 29th Mar 2017, 21:07   #1
Kalcifer
Itís fun to do the impossible.
Kalcifer's Avatar
Kalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on youKalcifer - may the hammer of Bindi be bestowed on you
Sapphire RX 480 crashing
Hi All.
Info for those with issues...
There is a manufacturing defect with some Sapphire RX480 Nitro+ 8GB OC cards.
Prolonged use can cause some cards memory to overheat, resulting in the crash of the game. In my case, shadow warrior 2, total war warhammer, and 7dtd after about an hour or two of play.
After trying everything from https://community.amd.com/thread/210786 I contacted manufacturer and overclockers, they are aware of the issue so I have returned the card for a repair/replace/refund...
Troubleshooting included:
  • Clean Wipe of Drivers
  • New Drivers
  • Old Drivers
  • Clean OS Install
  • Underclocking the card
__________________
-CASE- Fractal Design Define R2 Titanium -CPU-i7-4790K @ 4.00 GHz -MOBO-Asus Maximus VII Ranger -RAM- Corsair Vengeance Pro Red 16GB (2x8GB) DDR3 -GPU- GeForce 670GTX -STORAGE- 2 x Crucial MX100 256GB SSD -COOLING- 4x140 + 3x120 Fractal Design Fans - 2x140 + 2x120 DEMCiflex Dust Filters - Noctua NH-U12P SE2 CPU Cooler
Kalcifer is offline   Reply With Quote
Old 30th Mar 2017, 02:21   #2
TheMadDutchDude
Flying Dutchman
TheMadDutchDude's Avatar
TheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming SaiyanTheMadDutchDude is a Super Spamming Saiyan
That's very unfortunate. I was about to order six of them.
Thank you for the heads up!
__________________
ASUS X99-Deluxe/U3.1 | Intel Core i7-5820K @ 4.2 GHz | Custom CPU Water Cooling | Corsair Vengeance LPX 2x8GB | 2x ASUS STRIX RX480@RX580 8GB with VRAM strap mod | Samsung SM951 256GB NVMe + 2x Samsung 850 EVO 250GB in RAID0 | EVGA SuperNOVA G3 1kW | Phanteks Enthoo Evolv TG | CM Masterkeys Pro L | Logitech G502 | Logitech G920 | ASUS ZenBook UX305F
TheMadDutchDude is offline   Reply With Quote
Reply
Tags
crash, fault, freeze, rx480, sapphire
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
