Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 10th Apr 2017, 21:43   #1
|SIERO|-mods
What's a Dremel?
|SIERO|-mods's Avatar
|SIERO|-mods has yet to learn the way of the Dremel
Mod "SIERO" by |Siero|-mods
HI guys, i'm a italian boy and today i present my new mod, called "SIERO". I m going to mod the corsair spec-alpha, inspired by project alpha omega but only for the open frame design.
Components:
▪ i5 6600k
▪ Asus z170-a
▪ gtx 1060 gigabyte
▪ ballistix sport 4x2 gb
▪ enermax liqmax II 120s
▪ western digital 1 tb
▪ ssd PNY 120 gb
▪ Thermaltake smart se 730 watt
▪ corsair spec-alpha
stay tuned!!
(sorry for bad english)
|SIERO|-mods is offline   Reply With Quote
Old 11th Apr 2017, 06:19   #2
GeorgeK
Oooh purple
Moderator
GeorgeK's Avatar
GeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming SaiyanGeorgeK is a Super Spamming Saiyan
Moved to modding until there are pics of work in progress. Please report your thread once there are pics and I will move it back.
Also if you use the image button or alternatively the [IMG] [/IMG] tags around your images then they will appear as images rather than links - I have altered the one above this time
Cheers
GK
GeorgeK is offline   Reply With Quote
Reply
Tags
siero-mods, spec-alpha
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
