Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 12th Apr 2017, 14:12   #1
Pookie
Level 0
Pookie's Avatar
Pookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming SaiyanPookie is a Super Spamming Saiyan
Connecting VPN to Server 2016
Hopefully someone can help with this, basically I have the same issue as per this thread..
https://social.technet.microsoft.com...r?forum=ws2016
I have a bunch of Apple machines that are running Sierra and cannot use PPTP/direct Access to connect to the server. On server 2012 the RRAS options can be manually configured and I use L2TP with a Pre shared key which Sierra works great with.
But with the legacy options disabled on 2016 I am stuffed!
__________________
Unlimited Fibre Broadband 38Inc Per month including line Rental!
http://pulse8broadband.co.uk/fibreoptic-broadband
Pookie is offline   Reply With Quote
Old 12th Apr 2017, 14:16   #2
Votick
My CPU's hot but my core runs cold.
Votick's Avatar
Votick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming SaiyanVotick is a Super Spamming Saiyan
Not got a firewall to terminate the Apple VPN on?
Votick is offline   Reply With Quote
Old 12th Apr 2017, 15:49   #3
Margo Baggins
I'm good at Soldering
Moderator
Margo Baggins's Avatar
Margo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming SaiyanMargo Baggins is a Super Spamming Saiyan
i've used draytek routers for this as they support L2TP over IPSEC server and it's super simple, just use old ones and forward traffic to them from the proper firewall.
__________________
My Imgur
i7 6700k - 8GB - GTX 1070
keyboards.
Margo Baggins is offline   Reply With Quote
Old 12th Apr 2017, 16:01   #4
Pookie
Level 0
Pookie's Avatar
They only have the BT hub, and all the port forwards are good.
__________________
Old 12th Apr 2017, 17:06   #5
Margo Baggins
Moderator
oh it's easy then, sell them a draytek
__________________
My Imgur
keyboards.
Old 12th Apr 2017, 17:32   #6
Pookie
Level 0
Pookie's Avatar
That or find out how to make the changes to RRAS over powershell
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
